Old 18-02-2006, 05:41 PM   #1
sirhal
Kuga TF Trend
sirhal's Avatar
Default Wobbly front end
Hi All,
A little while ago I changed the front discs and pads on my AUI Fairmont. They were shuddering under braking and I figured that it was just warped discs. I checked the thickness and they could of been machined, but the new discs were cheaper
However a couple of weeks later on a trip to Sydney (from Brisvegas), they started to wobble again. : This was 4 months ago.
The strange thing is however, the wobble comes and goes. Sometimes it can go for a week without any vibration at all. But other days it is so bad that when you apply the brakes, the steering wheel shakes quite violently.
Any ideas???
You guys are pretty cluey. I thought I might check before I go pulling it all apart... again.
sirhal is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 05:58 PM   #2
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Location: on my p.c now with internet! ok i'll still use works internet too.
Try takening both front wheels off & then spin the rotors around to see if there any warpping has started. Look carefully as it mite only small. Mine use to do the same thing, some times it wobbly & other times it was fine with the standard ones. Since i replace them with performance rotors (DBA) i haven't had the problem come back. Cheap rotors are well known to warp easy.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 06:17 PM   #3
sirhal
Kuga TF Trend
sirhal's Avatar
Are warped discs the only thing than can cause this kind of wobble? Could we be talking calipers, bearings, faulty abs, steering, master cylinder, brake lines? used:
If the discs are warped then why does the wobble come and go?
Old 18-02-2006, 06:30 PM   #4
EvilChief
Boost Addict
lotsa things can cause a wobble in the front end one way or another ...
how is ur wheel balance and alignment?
tyres?
brakepads?
callpiers (pods)?
brakefluid?
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2006, 06:38 PM   #5
sirhal
Kuga TF Trend
sirhal's Avatar
tyres?
brakepads?
callpiers (pods)?
brakefluid?
wheel balance? - not sure. was done with last tyres
tyres? - seem ok. even tread wear
brakepads? - changed with discs
calipers? - well last time I had them out of the rods were hard to remove. Needed to bang it out, sand it, lube it and put it back in.
brakefluid? - never replaced it. Thought about flushing the entire system.
Again however, it comes and goes! thats the most frustrating part. If it were constant it would be easier to diagnose.
Old 21-02-2006, 12:02 AM   #6
Mechan1k
Mechan1k's Avatar
Check to make sure your wheel nuts are on tight ... this could be another symptom.
Sounds simple .. but this can be the case as well.
Old 21-02-2006, 12:46 AM   #7
JC
JC's Avatar
I think you may find it's the callipers. If they are/were getting stuck, then they could be pushing the pad on at an angle causing vibration.
Try this (on a deserted street would be good, so you don't get rear-ended):
1. Accelerate to 60, then hit the brakes with moderate pressure - ie bring the car to a stop as fast as you can without enabling ABS. Did the brakes "wobble"? I doubt it.
2. Now accelerate back to 60, and hit the pedal softly, as if you are coming up to a set of red lights that are about to go green. Then slowly increase the pressure till you stop (pretend the lights stayed red). If at any point the wobble returns, I reckon it's the calliper slides.
If it is the callipers, when you pull them apart this time, use a polishing wheel/wire wheel to polish up the slides, and liberally spray WD40 into where the slides go and clean out all the rust and muck in there. Then check the rubber boots on the slides and make sure there are no holes. Holes = moisture = rust.
I had a similar issue on the front left of my XR8 (brakes wobbled) and after fixing the calliper slide, the wobble has disappeared.
Ford Performance Club ACT
Thread Tools
Display Modes
