tyre fryer
hey guys
just wanted to know if anyone could help me out. my cars gearbox somtimes gets stuck in 3rd. it would be driving fine then id pull up at a set of lights, go to take off and it stays in 3rd. if i stop the engine then start it again its back to normal. i think it may be a sensor or somthing in the electronics, i was just wondering if this has happened to anyone elses auto, or if anyone would have any idea what it could be? any help would be tops thanks
visit www.beastclub.com.au |
it is definetly going into limp home mode. its weird how it re-sets itself but. it could be possible your ecu which controls the auto is stuffing up. other then that check the speedo sender unit and the cog inside it for damage.
That'd be the S5 solenoid. I've had the same problem. I think from memory Ford charge $400 to replace it, but it's a $70 part or something. Would take a couple of hours to replace yourself if you are mechanically minded.
Sundeep |
Nice car btw. I was checkin it out last night. Youd be the only car that left bayswater that DIDnt pull a burnout :thumbsup:
EF Falcon Sedan 5.0 auto with IRS "the man that crashs AFF" |
#5 | |||
mine did the same thing when i had the auto in it.... gave it a service and it was fine.
'93' EB fairmont 5 speed manual. extractors, high flow cat, 2.5 inch sports exhaust. Freshly painted in Cobalt Blue. lowered with ultra lows. 17 inch mags fitted. Just finished putting a low km el motor in her |
yer mine's doing the same right now
is you'r speedo working if not it will b you'r spped sender hang it over and you should b fine mine shat it self Again because i didnt bother swaping the 3 speed coge ofer to a 4 speed one so now it's bk in LHM one again bring on 5 speed ![]() |
Thread Tools | |
Display Modes | |
