The 'Stihl' Man
![]() Join Date: Jan 2005
Does anyone have any pics? Or know what it consists of?
In their parts list it mentions that for $390 you get a Ultra-Flow Intake Kit, 3" Mandrel, Coated, incl filter, etc, but thats also installed. Is this very different from the Pod Hi-Flow Air Conversion Kit which retails for $190? I figured if I pick up the parts it cant be that hard to install, a bolt on kind of thing. Or is that a waste of time? What have other EF/EL owners done? Would it be better to just go to an exhaust shop and get a 3' mandrel bent pipe made up, throw a filter on the end and then put that in the standard box?
![]() Join Date: Dec 2004
I'd suggest an ELGT snorkel and a good filter. Save your pennies for more worthwhile mods ;) A lot of that money could go into your upcoming cam!
*EDIT* you might already have one, since you have a Tickford motor. I'm unsure whether Ghias got the larger snorkel or not. Sure, overall a custom intake setup *will* help deliver more air, but for a stock-ish 4.0 you don't really need to go beyond the ELGT snorkel (or a trimmed AU Tickford snorkel) and a decent filter. -Dave- |
The 'Stihl' Man
Yeah EL GT snorkel was going to happen, just been lazy about it really. I already have a K&N panel filter so I guess thats done then...LOL
Ghias came with povo standard snorkel, at least I a pretty sure, either way its not big.
Well I'd give the custom intake a miss all the same. Hunt down an ELGT snorkel on ebay or from a wrecker...
#5 | |||
Back to Le Frenchy
Been there, done that. Don't bother. That is unless you want it there because it looks good, which it does but as for improving performance it is minimal at best.
#6 | |||
likes falcon's
throw filter in the box with el gt snorkel you only need a elbow peice about 40odd cm's long as the rubber bend and plastic that sits on the rocker cover is good for heat compared to a mandrel equivelant
www.carhubsales.com.au |
#7 | |||
The 'Stihl' Man
Thanks for the info guys, looks like I might just stick with the EL GT snorkel then. You can get one from SVO for like $60, so I think your paying roughly $15-20 for the SVO badge as its exactly the same as an EL GT version. Oh yeah, and it will be 100% new products here on in ![]()
#8 | |||
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
@jas_23_
go to this link, its got pics of what i did, total cost was about $40 including pod
the pipe is just 90mm pvc, it hasent warped and ive been on long drives with temps at around 40 degrees. http://www.fordforums.com.au/showthread.php?t=74770 |
Oops, I slipped....
The G&D intake flows 8rwkw more at idle than the JMM one, G&D even proved it on their dyno, so it must be true.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
#11 | |||
The 'Stihl' Man
#12 | ||
ORSM FORD CRUSIERS
i know this is turbo but the intake should be the same. on that side, here is my set up. might help.
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
#13 | ||
is that just a massive silicon joiner coming off the TB Tristan ?
#14 | ||
The 'Stihl' Man
That definitely looks the part, I was quoted $80 for the pipe work, which seems pretty reasonable.
#15 | ||
ORSM FORD CRUSIERS
my pipe work cost $40 for the stainless steel and then the silicon was a bit $$ at $70, but it look snice and neat.
