Old 01-08-2008, 09:02 AM   #1
The Mighty Red
The Mighty Red's Avatar
Default AU wont idle
Hey guys , I replaced the alternator on my AU yesterday no problem except now the car wont idle .....I am not sure if its related to the alternator or not.
the red light on the dash has gone off and the voltmeter on the dash is reading normal again like its charging ....it runs and revs fine with no missing but now as soon as I take my foot of the gas it stalls......
the engine has done 254,000 k's and until now never let me down in 4 years and 120,000 km's ......
The Mighty Red is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2008, 09:18 AM   #2
bodes-sh
did you d/c the battery when replacing the alternator? if you did, try doing the relearn procedure. it may also be worth cleaning out the isc solenoid and around the throttle body with carby cleaner
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2008, 09:21 AM   #3
The Mighty Red
how does restting the ecu go again? doesnt it include letting the engine idle for awhile?......isc solenoid?
Old 01-08-2008, 09:22 AM   #4
bodes-sh
idle speed controller. the big (well not that big) canister looking thing that sits on top of the throttle body with a wire hanging out of it
Old 01-08-2008, 10:49 AM   #5
aye you
The Origional, The Best
aye you's Avatar
idle with in in drive 2 mins ac on
idle in neutral for 2 mins ac on
idle in drive 2 mins ac off
idle in neutral 2 mins ac off
go for a drive for 10mins at varying throttle positions.
I believe i got that right
Current Mods
2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts
Future Mods
Lowerage on KingSprings Lows | Engine...Period | Sounds System
I Use And Recommend F1 Tyres And Wheels On The Gold Coast
Proud Supporter of Beat The Heat (NT)
aye you is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2008, 01:12 PM   #6
EvilChief
Boost Addict
also cleaning it helps ;)
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2008, 04:27 PM   #7
The Mighty Red
so how do i do the reset procedure when the car wont idle....lol
Old 01-08-2008, 04:33 PM   #8
aye you
aye you's Avatar
when this happened to my car turned out the PCM had fried, all due to a alternator failure causing a power surge. but i'd be tempted to think the alternator you put in is dodgy.
Current Mods
Future Mods
Old 01-08-2008, 05:50 PM   #9
The Mighty Red
I'm pretty sure the alternator (from wreckers) I put in yesterday is working ok.....I have driven it 4 or 5 times today and it IS charging the battery....
PCM?
I will buy some carby cleaner tomorrow and attack the throttle body
Old 01-08-2008, 08:09 PM   #10
bodes-sh
ecu normally in a i6. powertrain control module...does it idle at all or do you have to even rev it when you start it?
as for the reset, as above is close enough, normally in park a/c off 2 min, drive a/c off 2 min, park a/c on 2 min, drive a/c on 2 min, then drive for a few km
Old 02-08-2008, 01:31 PM   #11
The Mighty Red
It starts and then stalls straight after.......I have cleaned out the throttle body but has made no difference......I cant do the reset procedure because the car wont idle..
I really need to get a fix on this guys without going to a mechanic.....so how do i check the pcm?
Old 02-08-2008, 02:07 PM   #12
aye you
aye you's Avatar
odd question, is the lead on the ISC connected and make sure there's nothing blocking the connection.
Current Mods
Future Mods
Old 02-08-2008, 05:03 PM   #13
GK
Walking with God
GK's Avatar
Good suggestion.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 02-08-2008, 06:00 PM   #14
EvilChief
Boost Addict
did u clean the ISC itself? ie did u remove and cleaned the gung out of it? as a short term solution you can set base idle through teh stop screw but thats last resort
N12 Pulsar - sold
Old 02-08-2008, 08:43 PM   #15
The Mighty Red
thanks for the tip, I will have a closer look at the Idle Speed Controller tomorrow......
Old 03-08-2008, 12:55 AM   #16
GK
Walking with God
GK's Avatar
Cleaning ISC Valve
http://www.fordforums.com.au/showpos...9&postcount=43
Hope this helps.
Cheers,
GK
Now gone!
On LPG
Old 03-08-2008, 07:35 PM   #17
au2sw
Blown 5L coming
au2sw's Avatar
howd you go with the idling issue today? sorted or not?
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2008, 08:37 PM   #18
The Mighty Red
No its still not sorted properly.....have got it to idle here and there but I think I need to reset the ecu and if that doesnt fix it then maybe get a plug in diagnostic done on it......hopefully that can give me an answer...
