Old 06-08-2010, 02:59 PM   #1
The Monty
Just slidin'
The Monty's Avatar
Default Question regarding ignition timing
Ok, after the enormous help recieved on the last question, Ill ask another question.
Im running V-power, 98ron.
If I want to run an E10 95 (always used to run it before custom tune, ran sweet[pardon the pun]) how many degrees of ignition timing will I need to pull out?
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2010, 04:02 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
probably 5/8ths of bugger all
i know if it was a carby car you'd only look at about 2 deg
back in the day i used to ignore timing specifications
i'd just keep on retarding it until the pinging stopped
Old 07-08-2010, 06:52 PM   #3
madmelon
Zero if it's an AU6- has a knock sensor that should more than take care of that.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2010, 06:56 PM   #4
The Monty
Just slidin'
The Monty's Avatar
I had my old car ping really badly one day on a 98 tune when running 95. If I can hear it, Im sure that its doing damage.
Old 07-08-2010, 10:25 PM   #5
Mr Hardware
Well the egas motors ping really lots on hot days
they rocket on to over half a mil without incident
Old 07-08-2010, 10:25 PM   #6
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
Normally about 3 degrees, but the engine will need a little more fuel using e10 than it would using 98 oct fuel so it may be slightly leaner which may require a little more timing to be removed
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2010, 10:49 PM   #7
The Monty
Just slidin'
The Monty's Avatar
Just realised I wrote really badly, lol.
Thanks guys. I also talked to Chris from Bluepower what a wealth of knowledge.
Old 08-08-2010, 07:53 AM   #8
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
Somewhere between 2-4deg will do it.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2010, 09:59 AM   #9
T3man
T3man's Avatar
You set the timing to factory specs and let the ECU take care of it. How simple do you need it to be?
