Old 19-03-2012, 01:21 PM   #1
leonbray
Cougar Owner
leonbray's Avatar
Default Auto Window Down for AU Ute
I'd like to add auto down to the driver's window of my AUIII XLS
I've looked at adapting the master switch unit from Ghia but couldn't figure out how to get it to fit into the ute two (2) switch moulding - like it was suggested in one of the other threads.
I'd prefer to have just 2 window switches in the drivers side armrest, with auto down on drivers window
Am I missing something?
Leon
AUIII XLS with Tickford bits, 1968 XR7 (302W 4v roller cam), 1969 Convertible (302W),
leonbray is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 01:59 PM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: Auto Window Down for AU Ute
can't be done without major rewiring the whole wiring harness and BEM are different you would need to modify a high series sedan main body harness then use a high series BEM and change both door harnesses, even then you would still have a 4 switch unit in the drivers door with 2 dead switches
[SIGPIC][/SIGPIC]
Rides:
Old 19-03-2012, 05:39 PM   #3
Ladiesman217
I can count to potato!
Ladiesman217's Avatar
I was just thinking about the same thing today in my ute 'bout 2 hours ago. Damn I miss that auto-down button :(
AU III XR8 UTE
Ladiesman217 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 06:50 PM   #4
foxtrot3
foxtrot3's Avatar
Hi. DEI ( http://www.directed.com.au ) have a window lift module which gives one touch up and one touch down without an alarm and with almost any alarm windows up on locking and with a suitable alarm you can add window vent (down 25mm at a time) or window open. Put one in a mates xh and its real trick. Cheers MD
HI
I'M MICHAEL
Old 19-03-2012, 08:05 PM   #5
leonbray
Cougar Owner
leonbray's Avatar
http://www.ponyperformance.com/specials2.html
just found this one that might work
Leon
Old 19-03-2012, 09:00 PM   #6
foxtrot3
foxtrot3's Avatar
Hi. Looks like a bargain but check the international shipping cost before you order one. Cheers MD
HI
I'M MICHAEL
Old 19-03-2012, 09:04 PM   #7
Ladiesman217
I couldnt find one on their website
AU III XR8 UTE
Old 19-03-2012, 09:57 PM   #8
foxtrot3
foxtrot3's Avatar
Hi. Try this one http://www.ebay.com.au/itm/Viper-DEI...#ht_548wt_1396 . Cheers MD
HI
I'M MICHAEL
Old 20-03-2012, 03:51 PM   #9
Ladiesman217
Mmm, that's a window lifter.
AU III XR8 UTE
Old 20-03-2012, 06:38 PM   #10
foxtrot3
foxtrot3's Avatar
Hi. Very clever Thats what I said it was AND it does one touch up and one touch down (just by itself-no alarm needed) and with any alarm a window lift and with a suitable DEI alarm window vent and open....NOW PAY ATTENTION THIS TIME, I might be asking questions later. Cheers MD
HI
I'M MICHAEL
Old 04-04-2012, 06:10 PM   #11
foxtrot3
foxtrot3's Avatar
Hi. Sorry I was wrong..... ...... The window lift module that does everything I said is the DEI 530T (not the 529T) Cheers MD
HI
I'M MICHAEL
Old 04-04-2012, 06:36 PM   #12
leonbray
Cougar Owner
leonbray's Avatar
I ordered one of these. Based on discussions with the vendor and details of AU wiring diagram, it should work on the ute
Will post an update. Hopefully it will arrive tomorrow and I can get it done over easter
Leon
Old 05-04-2012, 01:32 AM   #13
Ladiesman217
Awesome, cant wait to see a result!
AU III XR8 UTE
Old 14-04-2012, 07:49 PM   #14
leonbray
Cougar Owner
leonbray's Avatar
OK - the PonyPerformance one touch window module kit will work in an AU ute
This is what you get in the kit
and you need to follow these instructions
but use the AU wiring diagram to find the right wires
The wiring conversion from the Mustang swith to the AU switch is
Blue/Black = Grey/Yellow
White/Black = Yellow
Yellow = Red
Black = Black
Remove the Switches by gently levering the trailing edge of the switch panel. It is held in place by a spring clip
Remove the plug from the switch (the white plug is the drivers window) - you have to reach between the switches and depress the catch while you wiggle the plug to break contact with the switch
Eyeball the switch so you know where the wires run. Check that the grey/yellow wire is 12V when the the ignition switch is in accessories or ignition.
If you wire the unit into the loom using the included wire tapping terminals, you will not be able to get the switches back into the arm rest because of the bulk of the terminals
The unit will fit more easily if you solder the wires from the unit with the appropriate wires from the switch or join the wires by replacing the female terminals in the plug
The one touch unit will fit inside the front or rear of the armrest
Test that everything works before reinstalling it all
Leon
Old 15-04-2012, 11:29 AM   #15
Ladiesman217
Wowee-whoa-whoh! Good stuff, I think I'm a purchase me one of these right now. Thanks mate!
AU III XR8 UTE
Old 02-05-2012, 04:59 PM   #16
CFOUR
The Destroyer
CFOUR's Avatar
Simple wiring instructions
Cut loom yellow.
Plug/switch end of yellow to module black & white
Module red- cut loom yellow
Splice module yellow to loom red
Splice module black to loom black
Splice module green/yellow to loom brown/yellow.
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
