Old 09-09-2012, 09:37 PM   #1
block58
block58's Avatar
Default Replaced IRS Upper mounts - still knocking!
So as the title says I spent a couple of hours yesterday replacing my upper shock mounts for the IRS, and expecting relief from the dreaded knocking noise that worn mounts create, I went for a drive and lo and behold, knocking continues just as it did, with perhaps the tiniest reduction in noise.
Any advice on what to check next? Cheers
FG MkII G6 Ecoboost in Lightning Strike
block58 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2012, 09:41 PM   #2
hales231271
hales231271's Avatar
Default Re: Replaced IRS Upper mounts - still knocking!
Did you place extra washers under the top shock securing nut?
If so was the ID of the washers large enough to fit over shocker shaft?
Dazza
hales231271 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2012, 09:47 PM   #3
block58
block58's Avatar
Yep, sure did. The job had been done once before (have just clocked 200,000kms) so I just reused the ones that were already on it, and they fill the gap between the mount and the thread.
Old 09-09-2012, 10:04 PM   #4
Day-mow
rexnet
Day-mow's Avatar
bushes flogged out? mine are sooooo past dead. i just cant be bothered wasting anymore money on the car
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 09-09-2012, 10:13 PM   #5
block58
block58's Avatar
What is the best way to check is bushes have had it?
Old 09-09-2012, 11:50 PM   #6
mik
mik's Avatar
mines done(s2 XR6) 206000 k`s, the only noise i have had is the top shock mounts replaced early this year from memory, if you where to have a squiz at what bushes you can see, and if they are flogged out and knocking it will be fairly obvious i think, some blokes use a tyre lever to pry the suspension this way and that to get any excess movement, grab hold of tie rods and give them a good yank side to side up and down, stabilizer link the same, grab the wheel while it`s safely up in the air(on stands) give it a push pull from different spots see if any play.
personally i would double check the top mounts just in case of something amiss, fold the rear seats forward, pull the carpet and clips out/forward and get the missus to take you for a couple of blockys, and you can sit in the back, watch/listen to make sure it is not the top mounts still rattling, i used this method and it shows up like dogs balls.
Old 10-09-2012, 07:32 PM   #7
Day-mow
rexnet
Day-mow's Avatar
both methods work well.
Old 10-09-2012, 10:19 PM   #8
block58
block58's Avatar
Alrighty thanks to you both, I will take a look
Old 19-09-2012, 04:47 PM   #9
block58
block58's Avatar
So I went for a drive with the seats down so I could have a look at the mounts, and they are still moving up/down and squeaking. What gives? Is this normal or have I done something wrong when fitting them? They are brand new from a Ford dealership...
Old 19-09-2012, 07:03 PM   #10
Day-mow
rexnet
Day-mow's Avatar
are the washers squashed? are the bolts done up tight. i had same issue when i put SL's in and it turned out i didn't do a nut up.
Old 19-09-2012, 09:39 PM   #11
block58
block58's Avatar
Ill have to double check
Old 20-09-2012, 05:52 PM   #12
block58
block58's Avatar
Well I added another washer just to be sure and re-tightened all the nuts with extra leverage and no luck. Will have to take it to get all the bushes checked out.
