Whoa, this is heavy!
Gday all
Ive given the search function a good workout but I just cant seem to find what I'm looking for, everyone seems to be swapping either base to xr or low to high series.... My question: Would an au2 fairmont cluster be easy enough to make work in an au1 fairmont? Likewise for a series 2 climate control unit (which I am led to believe is a straight swap?). I just wanna lose the red leds mainly, the cc unit is close to cactus (standard) and the cluster display, even though working good, is still a PITA to read. Im thinking it would be an easy enough swap due to lack of dte on the cluster and 1/2 fairmonts sharing similar parts? Any thoughts on the subject before I start blowing cash at the wreckers? :P Cheers in advance
Liquid Silver 2002 AU III Fairmont wagon Le Mans Red 1990 SA Capri Turbo
cluster is a no go been there done that. the steering wheel stereo controls are linked to the cluster ( something to do with the speed alert in the S1) it will cause you all sorts of dramas. not sure with the climate control. only possibility is if the cluster LCD displays are compatible you might be able to just swap the displays ( never looked into that)
[SIGPIC][/SIGPIC]
I knew some ford engineers were a bit backwards (inlet manifold vs dizzy cap on early e series) but to loop speed alert from the cluster through the steering wheel to the seperate trip comp? Jeezus Johnny
![]() AU1 red leds not looking so bad anymore.... RE: climate control/trip comp thingy......any tried a s2 one in a s1? Thats my main bugbear, hate punching buttons wildly trying to get the ac on cos I cant see what im doing lol
I once tried a S1 cluster in a S2 ( long story why) and soon as I turned the ignition the stereo shot up to full volume just about blew my ears off
[SIGPIC][/SIGPIC]
I can relate, fairmont xr dash in place of a digital one in an nc ghia....thought I could play woth the wires a bit and get it to work (was in an experimental mood), fired her up to a plethora of warning lights, trip comp beeping off its nut and a really rough idle....it was then that I realised backyard electronics are not my thing.
