Old 15-08-2015, 03:55 PM   #1
david lee
Default heater switches
can the heater switches be removed by just removing the radio suround panel as that panel clips in to the big oval dash suround thanks
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2015, 04:35 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: heater switches
Hi. You need to remove radio to expose 2 screws holding the big oval panel in place. After the screws are out the panel clips in place. Cheers MD
HI
I'M MICHAEL
Old 15-08-2015, 05:47 PM   #3
david lee
yes but the black panel around the radio slips in to the big oval facia panel which im hoping comes out separately
Old 16-08-2015, 03:40 PM   #4
FOCUSonTHIS
FOCUSonTHIS's Avatar
The radio comes out first, then the heater controls. Then the oval facia.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
FOCUSonTHIS is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2015, 06:29 PM   #5
foxtrot3
foxtrot3's Avatar
Hi. If its a factory radio the front of the radio is fixed to the rest of the unit. If it is an aftermarket radio it will be mounted in a sleeve that will stop access to the screws. Either way the radio will need to be removed. Cheers MD
HI
I'M MICHAEL
Old 16-08-2015, 08:18 PM   #6
Fyrestorm
Spanner Thrower
i know series 1 AU's have 4 screws holding the tear drop, pretty sure S2/3 would be the same. but heater controls on the S1 i know are held to the teardrop with 5 screws, not sure with S2/3.
1999 AU Futura Wagon (Nickname Betsie the Barge-***)
Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG.
Awaiting Wife Approval Mods:
TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things!
Fyrestorm is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2015, 11:25 PM   #7
david lee
yes there are 4 screws that hold the heater switches to the oval surround which tells me the the whole oval panel must be uncliped to get to the screws
