Old 15-02-2006, 02:14 AM   #1
EAman
Ea 1990 with ef head
EAman's Avatar
Location: recently relocated from gipsland to newcastle
Question Ea air con problems Need help
Hi guys here is my problem
I recently bought a 3.9 mpi ea with a Ef head on it and i had the aircon re gassed in november for the summer all of a sudden it has stoped cooling there is still good gas presure in the air con lines well at least if you press on the valve it nearly blows the hair of your head so does anyone have any ideas????
EAman is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 02:52 AM   #2
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
is the clutch engaging?
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 03:21 AM   #3
EAman
EAman's Avatar
when you press the ac button you here a click under the bonnet not sure if thats the clutch engaging or not though
Old 15-02-2006, 07:34 AM   #4
vanessa0305
vanessa0305's Avatar
that click is the clutch engaging. I think having been regassed in November you should be able to take it back and get it tested for a leak...If there is a leak then it wont cool as much even if there is gas in the system. I found this out when my compressor seals went. It was leaking and not cooling even though I still had some gas.
vanessa0305 is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 07:54 AM   #5
LTDHO
The one and only
LTDHO's Avatar
There is a good chance there is a blockage. Which will mean you still have pressure and the clutch will still work.
First confirm the clutch is working. With ignition on ask someone to switch AC and watch the front of the AC pump.
Then run the AC (engine running of course) and see if any pipes have dramatice temp change.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 11:21 AM   #6
EAman
EAman's Avatar
also thismoring while doing this i have noticed that it sounds like there is a blockage up in the fan system now to
Old 15-02-2006, 11:23 AM   #7
EAman
EAman's Avatar
oh yeah its not in the pick up under the glove box were the occasonal rapper or some other stray thing have been sucked up!!!!!!
Old 15-02-2006, 01:01 PM   #8
EAman
EAman's Avatar
upon removing the cold air intake i found that the previous owner had boared out to 2.5 inch holes in the snorkel should i block these up or what
Old 16-02-2006, 03:31 PM   #9
EAman
EAman's Avatar
it apears the clutch is working
