Old 20-06-2018, 04:08 PM   #1
mikeeman_ford
EXR-699
mikeeman_ford's Avatar
Default Door Leaks
Hi Guys,
Please point me in the right direction if there is a post already. I have searched without luck.
i have an AU sedan, i am getting water on the foam insulation towards the front of the passenger door and the speaker is all rusty. The weather strips are bone dry with dust underneath them on the glass, the side mirror gaskets are also bone dry, and the rubber around the door and the door frame are also dry after an evening of rain.
The opening for the wiring on the side mirror (under the gasket) is also dusty/bone dry.
I am stumped, any suggestions where to look next?
Appreciate the help
Go Pedal = Fun Pedal
AU XR8 Tickford 200kw
Visit my Blog lovemyfalc.blogspot.com
RIP - AU1 1999 XR6 VCT, Forever in my heart.
mikeeman_ford is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2018, 05:16 PM   #2
Mont5.0
Mont5.0's Avatar
Default Re: Door Leaks
Take door trim off and have someone hose from outside whilst your inside??
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2018, 05:44 PM   #3
macman
macman's Avatar
Definitely this...
I had a water leak into the drivers footwell of my TE50 which I made every assumption as to how the water was getting in, even to the point of having the windscreen replaced.
Only after continued leaks, and having NO idea where it was coming through from, I ended up sitting in the car multiple times in the pouring rain or with the hose on the roof to find the leak.
Turned out water was defying gravity and getting in through a pin hole in an obscure place that I would never have found (or believed) it I hadn't seen it with my own eyes.
A pinhead of quality sikaflex seam sealer fixed it. This was after stripping the interior, removing the headliner, replacing the windscreen...
macman is online now   Reply With Quote Multi-Quote with this Post
Old 20-06-2018, 06:47 PM   #4
mikeeman_ford
EXR-699
Thanks guys, thats the next step i guess. i am just curious if it was common...........like the awesome actuators......someone at ford dropped the ball on that one
Old 08-12-2024, 10:10 PM   #5
clevo400
400 Cleveland
Hey, it's the window strip on the outside of your doors. They shrink and water leaks into the door and behind your door card and foam and rusts the speaker. I can't find where to buy them as all 4 strips on my BA Sedan have shrunk.
clevo400 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2024, 05:26 AM   #6
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Originally Posted by mikeeman_ford View Post
...AU sedan, i am getting water on the foam insulation towards the front of the passenger door and the speaker is all rusty....
Quite a few years ago now, but I had the same problem and seem to remember fixing a leak from where the side mirror attaches, the rubbery gasket was full of slimy gunk and soaking wet. Cleaned the gasket, and probably put some silicone around the hole in the door.
lol clevo400. Just noticed this thread is 6 years old!
AMB is offline   Reply With Quote Multi-Quote with this Post
