ROCKING THE EL FUTURA
ok guys realy need help on this on iwas instaling my old stereo back into the car tsting it in the prosses o see if it work or not as you do, when i finished all the wireing and soldering i put it in the socket turned tha car on the deck blew its fuse, i replace it but still nothing ive checked the fuse box but realy dont know which fuse is for the stereo as nothing is numbered on this thing help please any one got a diagram and which fuse it is..
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
Fuse 9
15 amp blue fuse. Also see if the head unit has a reset button. |
3rd across from the right, Top row.
Flairs - Truckers Delight
Or you could have just searched:
http://www.fordforums.com.au/showthr...t=fuse+diagram Took me about 20 seconds EVERY AU OWNER SHOULD HAVE THIS FUSEBOX DIAGRAM IN THEIR AU'S FUSEBOX also make sure you've got enough spare fuses and the factory fuse puller tool ![]()
thanks guys...
Do the engine bay fuses just pull out or is there some tricky catch that stops them from being pulled out? I don't want to damage them.
Hi. Some of the main fuses are bolted in place, you need to take the fuse box apart to get to the bolts. Cheers MD
