Old 30-07-2006, 08:00 PM   #1
stinger73
Default Removing Door Trims
I give up. I have been trying to remove the drivers door trim on a AU1 Fairmont and it doesn't seem to want to come off. I have removed the screws around the door and a bolt towards the top left corner. I also removed a screw under the power window switch. Am I missing something?. Is their another fastener hidden there somewhere?. I thought is would be pretty straight forward, but it has me stumped.
stinger73 is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2006, 08:04 PM   #2
AUXRVIII
There is a second bolt behind the door opening lever bezel.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2006, 08:48 PM   #3
b2tf
not here much anymore
b2tf's Avatar
One behind the door handle itself, if you pull the door handle as if you were opening the door, you can slide off the plastic surround behind the handle. Slide that off, and there will be a 10mm bolt there.
On the trim there is also a round trim cover, looks like a circle in front of the grab handle. If you pop it out, there is a 10mm bolt behind it too. Then you should be right to pull the trim off.
If its the drivers side, you'll need to slide the trim off the lock button at the top as well.
2024 F150 XLT
