Old 25-08-2011, 09:22 AM   #31
FreddyDUZ747
FreddyDUZ747's Avatar
Default Re: 300mm brakes vs 322mm. Is the extra 22mm worth it?
What about the C6 premiums,normally only a few hundred more than the 322's.
FreddyDUZ747 is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2011, 09:44 AM   #32
MAD
Petro-sexual
MAD's Avatar
You asked "is it worth it" but you never defined what 'it' is.
If 'it' = $50 then I'd say definitely yes.
If 'it' = waiting a couple of weeks longer to find the parts, then I'd say yes.
If 'it' = buying more parts compared to the other, then probably no (refer first point)
Given the option of either for free, no one would choose the smaller of the two.
It's not only about leverage, it's also about pad swept area.
- The Story
Old 25-08-2011, 10:02 AM   #33
FGII-XR6
FGII-XR6's Avatar
if you want to know if 322s are worth it and find a good package look at this thread http://www.fordforums.com.au/showthread.php?t=66266
they are site sponsors and have a good reputation
[SIGPIC][/SIGPIC]
Rides:
Old 25-08-2011, 10:45 AM   #34
b2tf
not here much anymore
b2tf's Avatar
Check my posts in the end of that thread.
2024 F150 XLT
Old 25-08-2011, 10:51 AM   #35
b2tf
b2tf's Avatar
Is the extra 35mm worth it - as in 322mm vs 287mm is what I was refering to.
2024 F150 XLT
Old 25-08-2011, 10:59 AM   #36
MAD
Petro-sexual
MAD's Avatar
But that doesnt describe any 'worth', it's simply asking if one is better than the other, in which case of course bigger is better.
Like I said above, if both options (300 and 322) were available for free, why would you choose the smaller.
'worth' becomes a consideration when there is a cost. Be it time, money, or something else.
- The Story
Old 25-08-2011, 11:36 AM   #37
FGII-XR6
FGII-XR6's Avatar
I rang them a few months ago they will do the kit without rotors as they said nothing wrong with having spare pads though and unlees you are going braided lines you will need the lines
[SIGPIC][/SIGPIC]
Rides:
Old 25-08-2011, 11:38 AM   #38
b2tf
b2tf's Avatar
Whatd they quote you for the kit except rotors?
2024 F150 XLT
Old 25-08-2011, 03:42 PM   #39
b2tf
b2tf's Avatar
Righto - as I understand it here's the options I have. Correct me if I'm wrong.
1) Retain standard AUIII caliper, use bracket and get new lines to allow fitment of 330mm disc.
2) Get BF XR8/Territory setup which is new calipers, brackets and lines. Add rotors and pads to suit.
3) Get BA spec caliper which allows fitment of 300mm disc and lines to suit.
All have their pros and cons. Am I missing anything?
2024 F150 XLT
Old 25-08-2011, 04:30 PM   #40
RG
Back to Le Frenchy
RG's Avatar
Aust seriously I'd wait until a set of tickford premiums or the BA C5 premiums come up.
Out of those options though I'd just go the whole hog with the BF XR8 set up, what's the point in doing half the job?
Old 25-08-2011, 05:00 PM   #41
atec77
Wink Re: 300mm brakes vs 322mm. Is the extra 22mm worth it?
Ive been looking around for some brake upgrade options for the ute for a while as it still has the standard 287mm disc setup. I was keen on the BF> setup which takes things up to 322mm but the catch is I only want to buy the calipers and lines - not the rotors and pads which seem to be a part of all the deals. I work in auto retail so getting those bits nice and cheap isnt a big problem hence I dont want to buy them with the calipers.
I am seeing a lot of 300mm BA/BF brake calipers available though and I'm now wondering if that extra 22mm is going to make a major difference? I have previously had the 322mm brakes on 2 cars and was happy with them, but just wondering if I might chuck the 300mm ones on the current AU and see how it goes.
What does everyone think?
22mm ? not sure it would matter much but it might help as the increase in swept area might aid cooling ? , I went from 290mm to 355mm and added some pistons to the calipers on the daily , I do have problems with eyeballs falling out
under braking
Old 25-08-2011, 06:39 PM   #42
FGII-XR6
FGII-XR6's Avatar
I can't remember now to be honest I gave up on it for now as there were other calls on the finances. give them a call rather than sending a message, tell them you're a forum member they will give you your options and explain things properly for you
[SIGPIC][/SIGPIC]
Rides:
Old 26-08-2011, 11:49 PM   #43
JC
JC's Avatar
The larger the disc and more pad area you can get, the better. If your budget is endless, get the best you can afford. If not, then get the best you can afford. The 287mm AU2 brakes with slotted rotors and a decent pad are every bit as good as a stock 322mm setup for repeated hard brake application (such as a long downhill windy road, a race track, or just the traffic light to traffic light get to the speed limit as fast as you can....).
Ford Performance Club ACT
JC is online now   Reply With Quote Multi-Quote with this Post
Old 25-09-2011, 09:13 PM   #44
MGM
MGM's Avatar
i did the ba upgrade on my au xr6 ute and was a massive improvement, now i did au xr8 to ba gt brakeswhich have the original "oblong grooved" discs and when pushed hard there awesome, locks up the abs to easy though, which is coz of my LCA bushes. but for $200 it was a great upgrade, then i got braided lines which made no difference, just peice of mind when hard braking
MGM is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2011, 09:59 PM   #45
blueoval
Critical Thinker
blueoval's Avatar
braided lines gives a bit better brake feel after a while when hot and pushed hard. Thats all I have felt with them as well as the peace of mind.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
