#31 | ||
I'd go the Nvidia 7800GTX if I were you, assuming it's got 2 x DVI and all that. It also won't make any difference if you run 4 x 512mb or 2 x 1024mb memory sticks, except that in the future your upgrade path will be restricted.
If you're simply video editing, you'll also find that Intel dual core processors have a slight speed edge due to their architecture. For nearly everything else though, a AMD64 system is the way to go. In my experience, Gigabyte motherboards have always been very stable and feature packed, but lack 'expert' options like overclocking. If you're not interested in any of that, it's another alternative. Everything else looks good, though if you can wait a week, the Pioneer DVR-110 comes out, which writes DVD-RAM unlike the DVR-110D, and has (potentially) better hardware with means a (potentially) higher quality burn, important in a video editing machine. Make sure you stick with the Pioneer drives though...! Edit: Make sure you keep the DVD+-RW's firmware updated! The DVR-110D already has an update... http://www.pioneeraus.com.au/compute...isclaimer.aspx Last edited by BuuBox; 07-09-2005 at 07:28 PM. |
#32 | |||
http://www.madshrimps.be/?action=get...26&articID=305 |
#33 | ||
For video editing I would get 2 x 10K SATA 8mb drives and a raid 0 controller. The stripe will boost IO performance heaps. I did it and half of my problems with crashing during video editing disappeared. I did a lot of research to find the problem and it turned out to be IO.
High end video cards aren't necessary for video editing as there isn't a lot of graphic processing going on. For stuff like what Firefox7 does it's an entirely different story. For home, I wouldn't worry about Pro except you should get the 64 bit version because of the processor. |
#34 | ||
AKA MYTE8
The motherboard can handle Raid 0
ie: nForce4 Storage: - 4 x SATA 3Gb/s - 2 x UltraDMA 133/100/66/33 - NVRAID : RAID0, RAID1, RAID 0+1 and JBOD span cross SATA and PATA
#35 | ||
beep beep
Yeah definately a wise move if you are going to be streaming lots of data to have an OS/Application disk and a seperate disk(s) for your work. Oh don't forget FAT32 means 4GB file sizes (last time I checked) you will want to use NTFS on your workspace to allow for larger files
Nothing to see here, move along, move along... |
#36 | ||
AKA MYTE8
OK, looks like the important things for video editing is:
1) Fast Disk access 2) Fast CPU 3) Lots of RAM
#37 | |||
it is what you also need to play new video games :nutsycuck |
#38 | ||
get a commodore 64
#39 | |||
Games are some of the best benchmarks as they use a lot of resources and have sloppy code :P
Video editing also needs a lot of disk space doesn't it?
#40 | ||
AKA MYTE8
I think I will replace the graphics card with a:
XFX Nvida Geforce 6600GT. PCI-E 128mb and use the money I save to buy 2 faster disks instead of one disk and a high end graphics card that is not required for video editing.
#41 | |||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
XP Pro is better than Home. If you build for a fast video editing system you'll also get a pretty damm goog game set up as well. Uncle_Ken ![]() PS Great Thread, I'm nearly in the market for a $3K set up soon. Will follow up on some of the sites listed by you guys. Ah what could better, Fords and computers OK Beer, Fords and computers OK OK Girls, Fords and computers (and friends)
#42 | |||
Uncle_Ken ![]()
#44 | ||
AKA MYTE8
I have another idea now..
Since I want to drive 2 19" LCD screens via a DVI output, I could use the card I mentioned above which is about $250 or I could buy 2 of them or even 2 MSI NX6600GT TD128E cards for around $220 each and upgrade the motherboard to the ASUS A8N-SLI for $25. As the motherboard has 2 PCIE x 16 slots I can run each screen off its own card(without using SLI mode which only works with one screen) New Config: ========= ASUS A8N-SLI MB $190 AMD64 x2 Dual Core 3800+ $513 128M MSI NX6600GT TD128E $220 128M MSI NX6600GT TD128E $220 Avermedia Digital HDTV card $100 2G (2x1GB) DDR400 Kingston $360 250G 16M SATA2 HDD $167 Pioneer 110d DVD RW $ 70 Case ???? Windows XP Home $125 ============================== Total: $1965 (+cost of the case) ============================== Thinking about the video editing stuff I will be doing, the STATII disk might be OK, if its not I will add a second and use RAID0. Its not like I will be doing heaps of editing, but I will be doing more editing then game playing thats for sure. I guess Its more of a general purpose PC with a bit of performance for video editing Im after, more so then a gaming PC. I should of mentioned this earlier.(regarding video editing) I have a JVC MC500 which records in MPEG-2 format. Potentially I could be working with 4GB or more, which is around an hour. The only software I have at the moment is the editing software that came with the camera, which I haven't used 'cause it doesn't run on my old Ultra 60 Uncle_Ken: If you want a better video editing system this one looks OK(nice disk layout too): http://quantum-flux.freewebspace.com
#45 | |||
(a bit like cars). Check out the Bios to make sure you can easily set up both cards. Recently at work we had issues because the bios kept on defaulting to either the inbulit vidoe or the card, we couldn't get both going at the same time, had to change the video card. Looks like a sweet system for the specs you have so far, you'l have lots of fun with it. Uncle_Ken
#46 | ||
If your not using 3d at all id get even cheaper video cards and get the 4400 x2. They have 1mb cache instead of the 3800 and 4200s 512kb. With a better cooler the 4400 can probably reach the same speed of a 4800 as well.
#47 | ||
I use this to share use two screens at work. Ver 2 is free.
its simple and easy to use. http://www.mediachance.com/free/multimon.htm Uncle_Ken
#48 | |||
AKA MYTE8
ie: 3800 - $513 4200 - $708 4400 - $810 4800 - $1350 There is a big price jump between the 3800 and 4400. Not sure if the performance difference is worth $297.
#49 | ||
beep beep
Hi Goran,
I know you know this, but remember it anyway (for the input of other users) that RAID0 offers no data protection. Yes it can be fast, but if you lose a drive all data is gone. Therefore the disks in RAID0 config should be your scratch space only. Do not use them for finalised footage or long term copies of things you cannot bear to lose. I would have RAID1 of 2 x 160GB disks or there abouts for my regular hard disk usage, and then say a single 250 or there abouts single for video scratch work and then append to that in extra disks. Or have a single 160GB internal disk for OS and app's, and a RAID0 in either single or dual disk stripe and an external firewire disk of about 300GB for backing up data. Regards, Ian
Nothing to see here, move along, move along... Last edited by parawolf; 12-09-2005 at 10:21 AM. Reason: added name |
#50 | |||
AKA MYTE8
Even though the mobo has 2 PCI express x16 slots, both of the slots can not be run at x16. If you are using 2 cards and you have SLI configured, both cards run at x8, but only one monitor is supported. If you have 2 cards and you are not using SLI, then 2 monitors are supported, but one card runs at x16 and the other at x1. ie: There are two x16 PCIe slots that allow you to connect two x16 cards to the motheboard, but don't actually have x16 lanes of PCIe going to to them. Your choices are limited to having a x16 connection and a x1 connection (where the secondary x16 slot is able to utilize only a single lane of PCI Express) or having two x8 connections So I think I will buy the SLI motherboard and one card with 256MB memory and 2 DVI outputs. the SLI mobo only costs $25 more and comes with a 1394 port(The A8N-E doesn't) and then if I wanted I could add a second graphics card and enable SLI. Using the SLI mobo gives me an upgrade path. A cheap SLI enabled 256MB card is the XFX Geforce 6600GT which I can get for $295. Or maybe I should go back to the origanol card I had in mind or even higher, since I will be using one card to drive 2 monitors.
#51 | |||
AKA MYTE8
#52 | |||
beep beep
Fair enough - i find utilities like ghost really handy for rebuilding the OS and 'basic' apps + drivers from scratch REALLY useful. Build an OS image, and then have a bootable cdrom with the ghost.exe so you can restore your image rapidly. Just means you don't spend a few hours getting those drivers downloaded again, screen resolutions configured and network interfaces organised. Once you have that you can just do your dvd-rw's for restores of your "My Documents" directory or whatever. Just saves time which means you don't go looking for original media disks to get your NIC functional so you can get newest display drivers or such. Just a suggestion.
#53 | |||
AKA MYTE8
I use 2 monitors at work aswell and when I'm at home using one it feels strange. I can't wait to get the new system up and running.
#54 | |||
AKA MYTE8
#55 | ||
Oh.... lots of choices.
This is why getting a computer is not as straight forward as it looks. The problem for video at home is the raw files are large. I suppose unless you are running a network server with tape back up the issue of making copies (what ever type/format) will always be an issue. I would tend to KIS it. (Keep it simple). Burn to DVD or just drag and dump the files to an extra HD used only for backups. Uncle_Ken
#56 | |||
beep beep
#57 | ||
AKA MYTE8
OK Guys,
Here's what I ended up with, I did go over my budget by a bit.. ASUS A8N-SLI mobo AMD x2 Dual Core 4400+ 2GB (2x1GB) DDR400 Kingston memory XFX 660GT PCIe 16x graphics card 250GB SATA2 16M Western Digital HDD Pioneer 110D DVD RW DVICO Fusion HDTV DVB-T Plus 17 in 1 internal Card Reader Thermaltake VA700BWA Shark case Microsoft KB Windows XP Home All Up $2514 Plus I already have 2 x 19" LCD screens, All I need now are some decent speakers
#58 | |||
AKA MYTE8
You've changed your ID.
#59 | ||
hehehe. Thats normal. I needed a new vid card to play a game. $1300 and an upgrade later I was able to play the game ;)
I ended up with P4 3200mhz 2mb cache (640) Gigabyte 8I915P Duo 1GB Kinstone ram DDR 2 PC-4200 (2*512 matched pair) 256mb Gforce 6600 Centurion Case Seagate 200gb SATA hard drive 1.44mb floppy 16* dual layer DVD writer (Liteon) Microsoft keyboard and mouse After I played the game for a bit. I hated it! ![]()
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily). Tuned by Hallam Performance |
