#31 | |||
Tuned @ Pitlane Frankston
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
#32 | |||
The trick is to not do that.... ![]() That is an old pic of my ride, didnt bounce at all (standard length shocks all round and yes i still had bump stops) had to pick the rear up a little now because i been doing some towing latley and the towbar was near draggin on the ground :( But there is a little secret i could possibly share to cheat at the rear... I would say heaps of people have done it already tho.
PX3 Ranger - family truckster
BF Fairlong Ghia - boostlounge 11.26 @ 121 |
#33 | ||
man that thing is low. looks awesome.
Powered by Rollin Motorsport Turbo Barra ED 4L
#34 | ||
OK just a quick question..... I no you guys dont recommend monroe shocks. Someone already said they were rubbish. What can you suggest for decent shortened shocks for when I get my ultralows in a couple of weeks time?
Sorry to hijack the thread but I thought it would fit in here. |
#35 | |||
FirstOnRaceDay
MY BRAND NEW RIDE NC Fairlane GHIA Series II I6. Mods. 2.5" cat back Clarion HU Soundstream speakers amp and subs Lowered DL LTD rims ![]() For the moment... ![]() |
#36 | |||
![]() Join Date: Jan 2005
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
#37 | |||
look into koni, kyb or pedders shocks. i have koni's in the back and pedders in the front of mine, and i couldnt be happier.
#38 | ||
As OED said, Monroe are rubbish.
Get some koni rears and adjust them so they are nice and stiff, then have a chat to k-mac about some custom lowered springs. Surely there is no emergency that you need the car lowered NOW...It's worth saving the money and spending it on something that will contribute in no small way to the ride, handling and safety of your car... And maybe actually GET the wheels first, then see how they look with 'only' superlows on the car. |
#39 | |||
#40 | |||
EBII XR6
DEVLXR
#41 | |||
http://www.fordforums.com.au/showthread.php?p=1049933 i dont want to hijack this thread on 6cylEA
#42 | ||
if you really want to lower it without getting new springs, heres how to do it,
park it on flat concrete or bitumen, put blocks of wood under the jack points and if you want to lower it an inch, leave an inch gap between the blocks of wood and the jack points. then heat the springs and the car will drop onto the blocks, let them cool off and it's done, heat either the top half or the bottom half only, and it might keep a bit of springyness in the other half. but do not chop them as the end you chop will not fit the strut properly and it could slip out. |
#43 | |||
Oops, I slipped....
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
#44 | |||
need more boost
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
#45 | |||
What type of car was it not wanting to wanting to make the assumption it was an e-series. If it was somthing with IRS this might change the outcome And cut spring rock!!!!! |
#46 | ||||
need more boost
#47 | |||
#48 | |||
#49 | |||
need more boost
#50 | |||
#51 | |||
#52 | ||
yeah where i work we put a vp with chopped springs on the hoist and the springs just feel out.
Only happens on those model commos but |
#53 | ||
i can't chop them on mine because i have IRS, but i just put some king super lows in it and i'm happy with the height now.
#54 | |||
need more boost
#55 | ||
What's green is gold
dont chop the springs!! i did in my old EA and it was just waaay to bouncy, i ended up scraping a huge hole in the fuel tank and ripping off the rear bar, was bouncing all over the shop, about 30 km from home after taking a "shortcut"
![]() heres a pic of it minus 3 rear coils and 2 front... ![]() |
#56 | |||
#57 | ||
nope, i was young and dumb
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
#58 | ||
ELMONTY
one of ma mates cut his ultra lows in a vn commonwhore/toyota lexen, i dont know much about it however the ride wasnt that bouncy at all
97 EL Fairmont - Regency Red |
