#31 | ||
Scan the dyno chart and post it up.
#32 | ||
just downloading the driver for my scanner so i can... i'll post it up shortly. :(
#33 | ||
Click here for dyno chart..
http://img.photobucket.com/albums/v2...Picture024.jpg |
#34 | ||
Back on the road
Holy cow....that is seriously lean for WOT!!
Something wrong there, bad MAP sensor maybe? What sort of chip did they recommend? If it was a J3-type chip, then it is one of the many types of edit out there.... i.e. using a chip to recalibrate the strategy in the std computer.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#35 | |||
#36 | ||
Your AFR is running between 14 and 15:1 ... it should be somewhere along the lines of 11 to 12 from memory ... for a safe level ... someone will give exact readings for you though.
High 13's is starting to get too lean ... yours is higher ... no wonder. Then again ... could have been a faulty sensor though ... might be a dyno telling porkies. I'd say try another dyno that you know and trust and see what they come up with. But that AFR is too high. Do you notice pinging when you are really up it???? Looking at the graph it looks imcomplete ... I'd say because he backed out of it when he noticed the AFR readings were high. It was still on the rise though.
#37 | |||
Back on the road
The flat, dotted line is the measured AFR i.e. about 14.5:1 the whole way across... Something is not working properly on your car for AFR to be that high. Blocked fuel filter, buggered MAP sensor? Hard to tell without looking at the car, but best to take it somewhere to see if the computer is throwing any codes from a stuffed sensor. All of this is of course assuming that the AFR reading is accurate ;) Drop into one of the trusted forum sponsors down that way.....G&D, ACE, or Bluepower...(i dont know VIC, so not sure who you are closest to). In the meantime, try and keep out of the throttle.
#38 | ||
Elite Automotive
Contact: Paul 166 Beatty Road Archerfield QLD 4108 Phone - (07) 32742445 or Fax - (07) 3255 6529 www.eliteauto.com.au I take my car here, I can highly recommend Paul and Tim, I had a haltech fitted to my car and they explained every step they were taking and I'm more than happy with the result.I got a very healthy 201.7hp with just intake and exhaust. These guys know there stuff. They do all sorts of chips as well as edits.I went chip cause the haltech intercepter can handle a super charger better than a std puter(more boost), which I may do in the future.
Red bull gives you wings? ![]() |
#39 | |||
not here much anymore
Failing that, a Unichip and hide it behind your kick panel. I'll have mine for sale in a few weeks.
2024 F150 XLT
#40 | |||
#41 | |||
the whole point of it is to drop intake temp - It is a form of intercooling. why is it guaranteed trouble? sure you might need to replace plugs a lot sooner, and if you base your tune on the cooling effects of water and you run out then you could be in trouble but what else is the issue with it? |
#42 | ||
the issue, is turboed cars which were sold a water injection setup which involved, injecting a mist of water at the throttle body. Now when you're high up in the revs, shit goes wrong with it, and a mist turns into a jet of water, what do you thinks gonna happen? This isn't speculation, or what ifs, but what I have seen happen to a couple of cars.
#43 | ||
having said, that, what nudge was talking about is a bit different, having a mist shot in before the charger,intercooler,plumbing,to throttle body, I'd be guessing any hassles woulddn't be to major
#44 | ||
Smile
Glen ..your car is a time bomb mate.I would not get it edited at all.The car has a problem.Fix the problem as an edit or chip will mask the real problem.If it is say a fuel filter and you change it you will need to retune the car again!!
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#45 | ||
Its running an XR6 ECU with the forte engine... could this be the cause? I would have thought it'd be making it use more petrol if anything..
Another thing, it gets absolutely shit fuel economy too. |
#46 | ||
Put an XR6 HP cam in it and see how it goes. This might fix your problems.
Also get your fuel system checked out too
#47 | |||
Back on the road
The XR6 ran a higher pressure in the fuel regulator, affectively making the injectors larger. Because the XR6 ECU is expecting larger fuel injectors, it is commanding less injector pulsewidth than it it would for a Forte with the std fuel regulator. Long story short, get an XR6 fuel pressure reg on there, and reset your computer (to reset the fuel trims). Should be much improved.
#48 | |||
#49 | ||
^^you probably could, but you would have to get an edit probably...i think a xr6 fuel pressure regulator would be a bit cheaper than that
#50 | ||
Would i need a new fuel pump and injectors?
#51 | ||
prolby only injectors :P
#52 | |||
Smile
#53 | |||
Back on the road
#54 | |||
![]() Looks like i'll be off to ford this week |
#55 | ||
Ok guys.. sorry for all the questions, but will the XR6 fuel pressure regulator require the XR6 fuel rail too?
I picked up a new fuel pressure regulator today.. its a 3.5 bar one. |
#56 | |||
Rollin with the Autobots
~NUDGE~ |
#57 | |||
i put an 300kpa xr6 reg on mine a while back .i used an e series fuel rail and reg . to fit an au xr6 one you have to get the whole fuel rail with the reg. |
#58 | |||
Back to Le Frenchy
When I had the EL we upped the fuel pressure just by knocking the top of the reg in and the same has been done to my AU.
