Old 12-01-2009, 09:40 AM   #61
blueoval
Critical Thinker
blueoval's Avatar
Originally Posted by Sox
Like the guy below this post just said, you don't need a big cam, and probably the one you gave specs for earlier on in this thread or similar would the trick.
Personally I would look at a DEV3 or DEV3HL with some minor head work.
Should be a very nice well behaved performance street car.
It would likely still run mid to high 14's with normal gearing and street type running gear.
Good post Rik, thanks for that estimate. Thats basically what Im after. still quick enough for some fun but not over the top.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is online now   Reply With Quote Multi-Quote with this Post
Old 12-01-2009, 05:17 PM   #62
The Monty
Just slidin'
The Monty's Avatar
Question for people, cam specs are great and all, but what do they mean. Would anyone be willing to tell us what each part of the spec means? For instance :
IN. 35/75 290 230 110 .475" 2500
EX.75/35 290 230 .475" 5500
(the 230 is @ 0.75 duration)
What does each part mean relative to how the car will drive, and how power will be achieved.
The only parts I know are duration : (the 230 is @ 0.75 duration), the lower it is, the higher the compression will be, and .475" is lift, but what does each MEAN?
I ordered a cam today, from surecam, I was feeling lucky, so told him what I wanted, where I revved it to, the head I have for it to go in, yadda yadda yadda, and he told me he would do a nice one from billet, but the only info I got was duration, which is 218 @ .50, which I dont know much about, but said I would trust him to do me a grind, with the intentions of a 13. He said he will give it to me to run to 6000rpm, no higher is needed, and give me a bit more compression, and it would be classed as a street strip cam. Was also $499 delivered, for billet, which I didnt think was too bad, as I couldnt be bothered stuffing around with shims and whatnot.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 12-01-2009, 05:34 PM   #63
ayeyew
Teh Baest
ayeyew's Avatar
Lift - how much the valve is lifted off its seat at the lobes highest point. In General, opening quicker and further will increase engine output. Increasing lift without changing duration can increase power without much change to the curve.
Duration - Angle in crankshaft degrees that the valve stays off its seat during the lifting cycle of the cam lobe. Increasing duration keeps the valve open longer and can increase high-rpm power. Doing this increases the rpm range that the engine produces power. Increasing duration without changing lobe seperation angle will result in valve overlap
Overlap - Angle in crankshaft degrees that both in and ex valves are open. Occurs at the end of the exhaust stroke and beginning of the intake stroke. Increasing lift or decreasing lobe seperation increases overlap. Increased overlap = higher top end, but reduces low-end and idle quality (put, put, put)
dunno wtf half of that means, but it sounds good
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2009, 05:40 PM   #64
Mack 6
SUMP PLUG
Mack 6's Avatar
Shav, next time there's a meet, come over and come for a spin. I have a JMM DEV3HL with flasher and a few other things. I get about 144rwkw but oodles of torque. As mentioned earlier in the thread, I lose out a bit with the auto and not having a higher stall convertor fitted.
Don't ask me 1/4 mile times, but i can squeeze out a 1.33 at mallala, and that was before putting in 3.45's and a LSD
https://www.facebook.com/****boxmartini
https://****boxrally2015.everydayher.../martini-rally
Ford Courier XLT Crew Cab, 160rwkW+ AUII Forte Family Sedan is now the Race Car!!!
Mack 6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2009, 05:46 PM   #65
blueoval
Critical Thinker
blueoval's Avatar
Mate Im gonna take you up on that. You have basically what I am looking for. You just tell me when and where.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 12-01-2009, 05:51 PM   #66
Mack 6
SUMP PLUG
Mack 6's Avatar
Funny story. I drove past your work today according to your sig. I'll take you out if you can give us some advice on building my new house. LOL
Old 12-01-2009, 05:53 PM   #67
blueoval
Critical Thinker
blueoval's Avatar
you got it mate. Pop in anytime you see my car parked out front.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 12-01-2009, 09:34 PM   #68
Stav
Smile
Stav's Avatar
Originally Posted by Fordfan4u
There is a couple of cars hovering around the very low 14's, tripower 14.2, stav 14.2, stiddy 14.1 or a 14.0 i cant remember anymore and hamo 14.3 are the main ones that come to memory.
There was a bloke on fordmods with an AU XR6, It's Performance built motor with a haltec interceptor tune.. ran a 13.9 but his motor ended up blowing.
Theres a few quick 6's around that keep to themselves and aren't on the forums.
Firstly ..there is a bit of misinformation here.. No one from ford mods has run a 13.9 in an au. The person you are refering to is Shuggs. From memory he never got to the track.The fastest its performance six I know of is a ef falcon at 14.181.It is my friend fordfreak.It is not an au. It has been stated before this falacy and again I rebutted it.
If Stiddy has run a 14.1 it is news to me because I can guarantee you he would have at least called me to let me know.he is a mate!! Are you Nat? I spoke to Stidds a little while back and he told me he was going to sell it as an unfinished project as he bought a ba xr8.
When did stidds run a 14 or 14.1? I would have thought youd at least remember the time. Also last time we spoke it was not registered..who are you man?
tripower 14.226
stav 14.241
hamo 14.301.
These are the confirmed results so far. If stidds is for real ask him to email me . If he has done it then I take my hat off to hikm
Old 12-01-2009, 10:13 PM   #69
Fordfan4u
Im a newbie to this forum, I wasnt a fordman until I got my XR8. Matt (Stiddy) told me to come on here when I got the 8 so I could read up about them, info on them and what not and also for a laugh because of the 'n00bs'.
Stiddy's XR8 (the reason I got an XR8, He took me for a burst in his and I had to have one) is currently unregistered until he sorts out some issues, the 6 unregistered up until april 08 because he lost his licence and got it back in april.
I know he ran a 14.1, and swore he was going into the 13's that night, got a 14.01 or 14.10 and he was ****ed off and screwed the slip up and tried again for the 13's. Didnt get it that night. He was blaming the tune and limiter.
He's not on the forums anymore so really what anyone says about his car or times are pointless now, he's doing it to have fun in not to impress people on the internet.
Sorry stav, I dont know you, and to be blunt and honest, I dont think it really matter s what you say or what times you think can or cant be achieved from his car. Believe it or dont believe it, I was just making a comments on here about it. I know the car almost aswell as he does, because I've helped alot, especially over the last 4 months.
When was the last time you spoke to stiddy? maybe you should call him if your such a good mate and speak to him about it. Or email him.
Fordfan
EDIT: I just rang him and asked him, he said it was a 14.0@98mph.. BUT I was wrong about his RPM limit, its not set at 7600rpm, it was pushed that hard, but made no extra power so the limiter is set at 7000rpm and he said he still doesnt push it that high. Sorry for the mix up. He also just said to me not to get tied up in this argument because I wont win and it will go around in circles.
Officer: You've been drinking, i'll move your car...
Me: No worries, thanks, just so you know it has a brass button clutch.
Officer: [stalls] I cant find the button?
Me: What button?
Officer: The button for the clutch!!!
Me: [laughing so hard it hurts]
Fordfan4u is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2009, 08:22 AM   #70
Stav
Smile
Stav's Avatar
Fordfan
To be blunt with you ford fan..a friend of stiddys is a friend of mine Welcome to the forums. I had a chat with him last night and he did say the car ran the time. If Stiddy says he ran it I have no reason to doubt the guy.
Good going stidds. Ford fan ..next time stidds goes out I told him to let me know. We will meet and have a chat hopefully.
Fordfan..yes there are a lot of critics who do ask questions but I want you to know I now do not doubt what your saying. These is alot left in these cars .It is just finding the right combo and spending the money to make it happen. I was modifying my car until it started falling apart with age as they do. This did cut short my modifications as repairs were mandatory. Priorities did take centre stage so at this point om my 5th gearbox I am calling it a part retirement.
Old 13-01-2009, 02:32 PM   #71
Fordfan4u
Thanks Stav. Appreciate it mate.
Me: What button?
Old 23-02-2009, 02:49 PM   #72
Wade Cams
Former Sponsor
Wade Cams's Avatar
Wade Cams - dont do cams for AU's and even if they do they are re-grinds.
Since we are no longer a sponsor of this forum, l will confine my remarks to stating that both the statements mentioned above are incorrect.
Chris
Wade Cams is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2009, 02:56 PM   #73
blueoval
Critical Thinker
blueoval's Avatar
Originally Posted by Wade Cams
Since we are no longer a sponsor of this forum, l will confine my remarks to stating that both the statements mention above are incorrect.
Chris
Thats good to hear now Chris. Thanks for clearing this up
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 23-02-2009, 03:10 PM   #74
The Monty
Just slidin'
The Monty's Avatar
Ive seen multiple threads on AU cams in the Wade section, and the reply was always "We basically dont do cams for AU's".
Old 23-02-2009, 03:17 PM   #75
blueoval
Critical Thinker
blueoval's Avatar
That was my initial findings also, but things might have changed now. I guess an independent investigation is needed to confirm this.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 23-02-2009, 04:27 PM   #76
Wade Cams
Former Sponsor
Wade Cams's Avatar
OK, I'll probably get "banned" by the moderators for going into too much detail....but.....we have always indicated that we don't do AU cams where there is an AU ECU being used. The AU ECU does not, at least where our cams are concerned, adapt to the "changed" cam profile. When it's an AU hybrid, with an E series ECU, or, there's an aftermarket "programmable" ECU fitted, there have been no problems.
So, what we've alluded to, or at least should have, is, if you're running an AU ECU, don't use any of our cams. The engine will go into limp mode.
Sorry if we've misled anyone.
Old 23-02-2009, 05:47 PM   #77
The Monty
Just slidin'
The Monty's Avatar
Thats fair enough.
Im running a pretty big billet surecam on an AU ecu though, has never gone into LHM yet, makes over 125kw from 4400-6200rpm, and idles relatively good (never stalls at all).
Im using the CAPA Xcal1 to tune it (well Elite auto tunes it), maybe the problem was with the old tuning devices (chiptorque and unichip) and not the ECU? Or perhaps the tuner side of it.
Theres no way you should be banned by saying what youve said, its great to be able to have discussions about things like this. Thats what the forums are for.
You guys were going to be my choice of cam, but I just gathered you didnt do one for the AU, otherwise I may be running one.
No hard feelings, just a communication error.
And thanks for having the time to come on here and talk us through the details a bit more, we all appreciate it, knowledge of any sort is wonderful, and when that knowledge comes from a very reputable supplier of performance parts, everyone should be listening and learing.
Old 23-02-2009, 10:35 PM   #78
blueoval
Critical Thinker
blueoval's Avatar
Thats fair enough.
well said.
having a cam for an AU regardless of brand requires some sort of ecu recalibration of some kind anyway. Had we have known wade do cams for AU's with a proviso that an ecu chip or computer recal was needed, i believe you would have got more business.
Now that we all know this, we can include your cams as an option worth looking into.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 24-02-2009, 12:00 AM   #79
Fordfan4u
An AU ECU wont learn a wade cam? Sorry to say but RUBBISH. How come an AU ECU can learn to other cams, or learn enough to be atleast driveable? Wade cam's arent anything special, althought some are decent grinds, does mean they are anything special enough to throw an AU ECU into a spasm. :togo:
I would be steering well clear of Wade cams now just because of that comment. How can you expect a cam to work well when the tech doesn't know what he's talking about. :
Me: What button?
Old 24-02-2009, 04:54 AM   #80
The Monty
Just slidin'
The Monty's Avatar
Just having a look through your popular proflies for an E-series, and the cam I am using is a bit larger than anything listed in you range (.535 lift, 218@.050 duration) and it started first kick and everything. Idles great, good power, all it needed was a tune on the standard AU ecu.
Old 24-02-2009, 04:44 PM   #81
Stav
Smile
Stav's Avatar
Ive got a big cam in my car running with a piggy back ecu in the au.I have tuned it myself to idle etc. I think you will find that the au ecu is a definately a pig to tune but not impossible.The maker of my cam didt recommend the piggy back but it does run well.
Old 24-02-2009, 10:09 PM   #82
Sox
RIP...
Sox's Avatar
I had a DEV5 cam in a AU and it idled well, performed well, and behaved under all conditions.
Saw no reason to use a piggback.
Oval Everywhere...
Old 24-02-2009, 10:17 PM   #83
private9
www.TUFFCARPARTS.com
private9's Avatar
Interesting....
I've got an EF for my daily, that has a ported head and a Wade 977b cam. If it will run reasonably well with a standard tune for a while, I think I might swap heads onto my AU!
Old 12-05-2009, 12:36 PM   #84
blueoval
Critical Thinker
blueoval's Avatar
Can anyone tell me what the cost will be to put in an xr6 grind cam in my engine as well as time frame to fit it?
I was thinking about putting in a second hand xr6 cam in. Would I need to reshim the lash adjusters? Can I get away with standard valve springs? Is it a straight swap and tune scenario?
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 12-05-2009, 12:58 PM   #85
ebxr82nv
You would be better to get a custom ground billet to suit your shiiny new blower. What ever you do, upgrade the springs anyway. Doesn't hurt to over engineer.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2009, 01:01 PM   #86
blueoval
Critical Thinker
blueoval's Avatar
thanks. I guess its better to do it properly than to cut corners.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 12-05-2009, 01:10 PM   #87
ebxr82nv
I can't see any reason why you couldn't get the parts, fit and get it tuned for around $1500. I can't remember off the top of my head weather you need lift or duration on a forced setup.
Old 12-05-2009, 01:19 PM   #88
blueoval
Critical Thinker
blueoval's Avatar
I thought it was duration for forced induction.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 12-05-2009, 01:37 PM   #89
LG
LG's Avatar
JMM currently hold the quickest TQE time.. Enough said. Even with the seats out or no sway bar, whatever. They still hold the fastest time.
Like Soxx has said, you must choose the right cam, for the right application. There is no point in putting in a massive cam, designed to work with headwork, without the headwork. Sure some people still made power of those cams, but you will never get the most out of it.
And again, if you want that further optimum performance, get the tune to suit the engine, as with any modification.
Old 18-12-2009, 03:28 PM   #90
OED666
OED666's Avatar
Originally Posted by Stav
A OED who I consider a mate..had run 14.2's from memory first with the cam then modified a few other items to reach the 13.8 in a much lighter ed. Maybe he could fill us in on those mods?
I know I am thread mining...
These are the mods I had to my car when I ran a 14.2
AU XR6 Motor
Surecam
Pacemaker Comps
2 1/2" Exhaust
CAI
T5Z
4.11's
ChipTorque Chip
I had clutch issues (pressure plate not releasing at high rpm). So I went to a 10.5" BA Mk1 Flywheel and 10.5" clutch. Then I was able to run a 13.8 & 13.9.
Since then I havent been able to get my times that low since. I now have a 6 speed and hydraulic clutch. Its much harder to launch as there isnt as much "feel" with the clutch pedal. Plus I think the ol 4.0L is getting tired. Its copped 5 years of hard labour!
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
