Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
#211 | ||
Regular member
Yeh sure can, I ran a set of KMC's before my current setup - front offset between +36 to +20 should be fine, rear's +40 to +38 should be fine. No rolling required, my car was lowered..
CURRENT 2013 335 GT - BMC twin filter, Herrod IC, injectors, fuel pump, oil breather, SC pulley and balancer, X-force 2 1/2" cat back with high flow cats = 453rwkw. Thanks to Lee at Real Dyno performance. OLD 2010 FPV F6 FG - Herrod CAI, Pedders extreme XA's, Whiteline fr & rear swaybars, PWR stepped IC, injectors, turbo dump pipe with Venom cat, Herrod piping kit = 350rwkw |
#212 | ||||
Race Brakes Sydney
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
#213 | |||
Regular member
#214 | ||
Race Brakes Sydney
MATTHEW PEARCE
#215 | ||
My latest circuit wheels.
18 x 9.5 +22 all round. SSR Type C, clear by miles. https://www.google.com.au/search?q=s...w=1440&bih=663
FG XR6T ZF 350,000kms+ Road registered Lap record holder at Wakefield for any Ford or 2wd 4 door, of any make.....ever!! Wakefield 1.07.4 SMP GP 1.48.1 Marulan 43.4 Winton 1.35.4 |
#216 | ||
Pro Street Au Ute
I would like to know to if roh modena 3 piece fit 19 and 20. And also koya vizzo 20x8.5f and 20x10r will fit 6f and 4r brembos.
Daily. AU XR8 s2 ute auto Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker. |
#217 | ||
Koya Vizzo will not clear.
ROH Modena 3 piece are a Modular wheel made to order so they can make them to clear Brembos, however, you won't get much dish on them (which is like most wheels with Brembo clearance).
www.thewheeldeal.com.au
Australias' best deals on tyres & wheels FordForums Discount Coupon Code: 4rd4rum |
#218 | ||
Member
My ROH Moden in 19" do not fit, but as above, you could get them specified to fit. Essentially, if they have dish, then they are unlikely to fit.
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car. Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw. |
#219 | ||
GT-P With An Ego
You can get wheels with what I call 'fake dish', the spokes curl inwards at the very ends, so you get some lip on the rim, but the spokes are still spaced out far enough for caliper clearance.
e.g. like the Speedy Inferno's I run. ![]()
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, custom billet parts, beginnings of a stereo, much more - 340awkw. Ford Performance Club of ACT |
#220 | ||
Interesting thread. I see only 1 Ford factory wheels that fit over brembo's which are the BA XR8 18's. Does anyone else which other Ford Factory wheels fit..... EG FG 50th, G6E 19's etc etc.
#221 | ||
Matakana NZ
![]() Join Date: Aug 2005
Nope none, unless you now call factory FPV's Ford
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one. My Work Wagon AU Futura Wagon in Gold. On the Farm : Ford 6600 Tractor |
#222 | ||
Well unfortunately for me I can confirm that Koya Inox Kahn do not fit Brembo brakes
![]() ![]() ![]() a forum member who was good enoughf to let me try them on his Bremboed AU XR8 My wheels are 20x8.5 on the front and a lovely 20x10 on the rear. Off set I'm pretty sure was 38 for both fronts and rears I read here post 69 that they do fit http://www.fordxr6turbo.com/forum/to...-wheels/page-2 TBO I havent seen too many wheels I like that will clear, maybe the BF Cobra one are pretty good.Front foul up by about 12mm and after that we didn't even bother trying the dished out rears. Such a shame to get rid of these ![]() ![]() ![]()
Losing my patients with unfinished threads ![]() Did the ideas people helped you with work or not! ![]() |
#223 | ||
Regular member
#224 | |||
Race Brakes Sydney
That is a bugger but its the dished wheels that cause the most grief unfortunately.
MATTHEW PEARCE
#225 | ||
Sneaky
These are a 19" FPV rim, just put std centre caps to keep away the dishonest.
From reading this thread i've come to believe, i can definitely put 4/4 330mm, is it going to be of significant benefit to fit 355mm fronts? Please correct me if i'm wrong. [IMG] ![]() I was suggested to run AP Racing discs and calipers 4/4 with a set of EBC red pads. Then i started to see some prices and fell off my chair...... ![]() the pads i will hopefully use, but any suggestions as to a reasonable priced set of rotors and calipers that work as good as AP Racing? Ben |
#226 | ||
GT-P With An Ego
Good brakes aren't cheap.
You may be lucky to score a used set of Brembo's from RBS or maybe eBay for a more reasonable price.
#227 | |||
#228 | ||
Hi,
Does anyone know whether the Lenso D1R 18x9 will fit over brembo 4 piston front? What's the biggest offset without fouling on the guard?
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
#229 | |||
GT-P With An Ego
Speedy Cobalt in 18x8 will fit (one of the few 18" that will).
#230 | ||
hmm, I rang wheelworx today and they told me otherwise
Shame, they're a nice 5 spoke which I think suit AU/BA utes ... and Speedy Cobalts are just so ugly
#231 | ||
GT-P With An Ego
I was just after an 18 for cheap(er) semi-slicks. care not for looks.
#232 | ||
I just got a set of enkei pf01 in 18" that will fit brembos. Autotechnik do them for about $1600-$1700, I got mine from tirerack with some tyres tho.
Also saved 18.5kgs over stock wheels!! |
#233 | |||
Regular member
2 users like this post: |
#234 | ||
your car was used on the wheel deals FB site
#235 | ||
Are Starcorp Impuls' brembo compatible?
#236 | ||
just rang tempetyres and theyre convincing me the lenso D1R 18" 18x9 will fit Brembos. Anyone confirm for sure?
#237 | ||
#238 | ||
#239 | ||
anyone tried 19x8.5 adv.1 5.1 wheels?
#240 | ||
Is it safe to assume that wheels that clear 4 piston brembos will clear 6 piston also?
FG XR6T Ute
300rwkw |
