Old 11-10-2006, 09:29 AM   #1
sednwol
sednwol's Avatar
Default Steering feeling tight?
I was driving this morning in my S3 XR8 when the steering seemed to "tighten up", not the smooth flow with power steering. The power steering fluid, belts etc are ok and it certainly is working but seems "stiffer" some how? Just weird.The tyre pressures are OK and I have not hit any bumps. Just seemed to tighten up all of a sudden. Any ideas?
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2006, 12:44 PM   #2
Mechan1k
Mechan1k's Avatar
hmmmm ... maybe an internal fault with the steering rack ... sound strange that it did that all of a sudden.
Unless something may have fault or come undone (causing undue stress on the steering).
Old 11-10-2006, 01:58 PM   #3
b2tf
not here much anymore
b2tf's Avatar
mine is doing the exact same thing and i am getting it looked at this afternoon, will let you know what we find.
2024 F150 XLT
Old 11-10-2006, 03:41 PM   #4
b2tf
b2tf's Avatar
Got mine checked just then, the rack is fine as are all hoses etc. Looks like mine might be a blocked valve in the pump or something.
2024 F150 XLT
Old 11-10-2006, 10:37 PM   #5
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
if there is any slack in the uni-joint at the bottom of the steering shaft under the bonnet, and if its getting a bit dry ( needs a bit of grease ) / there is maybe a chance the uni-joint could of seized up a bit and locked into the slack. Maybe try grease it up a tadd then move the steering column up and down and back and forwards inside the car too a few times , just a suggestion , ? cheers .
:eclipsee_
