#31 | |||
Ok that great for you lol! As i have an AU1 i need a camber kit....bugger.. |
#32 | ||
Im not 200% on the whole camber kit thing... but im fairly sure thats the case. Id double check with someone who FULLY knows regardless.
AUII XR8 - 200kw Factory Body Kit & 17" Tickford Rims 5 spd Manual Lowered on King SL & SSL KONI "Yellows" Fully Adjustable Shocks 2.5in Stainless Herrods Cat back Black Leather Interior |
#33 | ||
Will do, thanks!
#34 | ||
Was It Something I Said!
depends on the size of your wheels. the bigger the more chance u will need a camber kit on the front.
when they do a wheel alignent the have a print out sheet of where the wheel sits angles etc. it goes minus and positive in degrees how the camber sits. if that makes sense. the tyre man should be able to tell u if u really need one however they will recomend it anyway for the sale but u can always findout after u chew a set of 2 front tyres :Pbest thing is get your springs and go to some1 u trust. ![]() |
#35 | |||
![]() Join Date: Dec 2004
I do know that the XR IRS is VERY camber adjustable... but the Ghia IRS isnt.. Ford scrimped on it and gave it a smaller adjustment bolt or something.
#36 | |||
I was told the same thing, local place told me I would need an camber kit to go to XR springs and shocks on an AU2 fairmont. |
#37 | ||
Its gone V
my mate asked for lowering and was told he didnt need one (AU XR8 III)
and my brother did (AU I Forte) |
#38 | |||
#39 | ||
Short throw shocks and Monroe GT which one or either?
#40 | ||
FRIKA
Had my car recently lowered with SSL Frotn & back. first changed the front shocks to short ones. Not longer after way less than 10000 kms my rear shocks died as well as the mounts and both needed replacing.
Personally i would do the lot in one hit
New 2008 LV Focus XR5 in Performance Blue
#41 | |||
I must say i didn't know this, but have recently noticed my shocks are definately making more noise. Id say ive only done around 6000 kms since i got it done. The shocks have done around 75,000 kms though so there probably due for a change regardless. But its a good point to remember.
#42 | |||
#43 | ||
Powered by Tickford
My ute has been lowered with lovells SSL springs, which are lower than kings SSL.
I used monroe sensa-trac shocks on the front, and a camber kit to get it all nice. Now if you think you can get away without camber kit lowering it that much, think again, mine had 4 degrees neg camber with only fitting less than half the shims i had, and only ended having one shim left from the kit to square it up. The sensa tracs work quite well, tho mine is quite stiff having 18* rims with 40 series rubber.
https://i.ibb.co/mF6pJgR/AUIIXR8.jpg SILHOUETTE AUII XR8 Leather, Premium sound, Momo S/wheel & gear knob, Sunroof, 20" Advanti Desires, Bulge, XR50 Front, Pacemaker extractors, Ballistic cats, 2.5" cat back system, Rebel bar & skirts, XR scuff plates, Kings SL & SSL springs |
#44 | |||
EB II
#45 | |||
#46 | ||
Wow, this has been dug up lol!
Well since then my car has been lowered on Kings Springs Super Low's all around, and im till using the stock shockers but am starting to feel it a bit lol! So soon i'll look into getting some new shockers! Also car is lower in the back then the front cause of the gas tank so its a tiny bit un-even! But hopefully when i get the new shockers it will even up! Cheers Simon ![]() |
#47 | ||
i had my superlows in for 15000km's and pedders did an evaluation on my suspension and said the shockers were fine. but i reckon there buggered now.
#48 | |||
Miami Pilot
![]() Join Date: Jan 2005
I can tell you from experience that cutting half the top coil off an AU XR8 Ute front spring drops ride height by 15mm, with little to no discernable difference in spring comfort & ride. On an unrelated (maybe) topic, the wagon now sits nice and even.
#49 | ||
Eat more peanuts....
Hey sorry to revive an old thread...
But SL does not mean Super Low, it means Sports Lows, and SSL is Sports Super Lows. Look at the parts catalogue for King Springs, there is no Ultra Lows, although there is SSL for XR's, which is essentially Ultra lows for standard cars. Futura = standard, Sports Lows and Sports Super Lows XR = Sports Lows (equivalent to Futura SSL) and Sport Super Lows (the magical "Ultra Lows"). Please correct me if I am wrong. Dan.
'04 Falcon XR6T Ute, Envi, K&N filter, F6 Intake, Twin 2.5" exhaust... Formerly owned: '99 AU Falcon Ute '88 EA Falcon GL |
#50 | |||
Miami Pilot
Kings come in 3 spring heights: Low, SL & SSL. Any of these can then be custom compressed, so I guess a SSL compressed another 10mm = Ultra Low, though if you want to actually drive the car, SSL is probably the lowest option that retains some semblance of practicality. Fit Lows to an XR and a Forte, and they end up at the same height. Same with SLs & SSLs. Just that you wouldn't fit Lows to an XR, because the factory springs are effectively the same height as Lows. So it doesn't really matter what the SL & SSL stand for, SL on an XR = SL on a Forte/futura/whatever. The thing that may be confusing is that some places talk in Stage 1 lowering, stage 2 etc. in these cases, Stage 1 for an XR = Stage 2 for a Forte, and so on. But if you buy king Lows, doesn't matter what falcon you fit them to, they should sit at around 670mm from bottom of tyre (ie the ground) to top of guard lip. SLs at around 650, and SSL at around 635 (give or take +/- 5 to 10mm on each of these, due to manufacturing tolerances, both by Ford and King Springs).
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, HSD/ShockWorks, black GT335 19” staggered replicas with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, machine face GT335 19” staggered Replicas with 245s and 275s, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT Last edited by JC; 01-11-2006 at 12:45 AM. |
#51 | |||
