Old 16-01-2007, 07:34 PM   #1
bad_mk1_escort
eskie freek
bad_mk1_escort's Avatar
Default asap help please au3 timing
we are just pullin a head of a au 3 and we are jest settin the timing and the top timing mark dont ling up with the bottom is this right plz help asap
black mk1 on goin project/ toy
94 ef xr8
toyota 60 series project with 6inch lift and 35z
Xd sedan project for sale
mk1 4 door project car for sale
Mk2 4door 1.6lt for sale
bad_mk1_escort is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 08:08 PM   #2
V8falcons
V8falcons's Avatar
firstly did the chain slip/jump a tooth on the sprockets,Im not sure the ratio from crank to cam on these but if the sprocket are different sizes turn the engine a few times by hand in the correct direction until they line up if not the chain may have jumped a tooth. and you may be bending valves as you turn it over so be carefull
Not a huge drama .Just set it up when you put it back togeather no 1 pistion @ tdc and set the head/cam up to compresion stroke tdc so both valves closed on no 1 cyl.
if it doesnt make sense get a service/owners manual as they usually explain it in there fairly well
V8falcons is offline   Reply With Quote Multi-Quote with this Post
