Old 25-01-2007, 07:27 PM   #1
Burley
CRE.87V
Default au vct xr6
hey all
recently just changed the oil temp sensor on my au because of the notice something was up....also got an oil pressure test...was ok....now its happening again..wat could it be could it be another sensor somewhere else
burley
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 08:12 PM   #2
Casper
Contributing Member
Casper's Avatar
oil temp sensor?
Can you explain what the actual issue is?
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 08:50 PM   #3
blackers10
blackers10's Avatar
if you mean the guage on the cluster it is oil PRESSURE and it has a ground fault at the sensor..causing it to read wrong
give it a better grounding(an O type terminal around it will fix the problem i beleive with a wire to the chassis ground)
good luck mate
