I came across a pair of front grey twin piston t-series tickford calipers and was wondering if these fit an au series one?
They should I think.
On another note, and seriously, if you decide not to buy them, PLEAASE give me the details as I will certainly buy them. Cheers, Matt. |
I don't think they do fit as the AU pads sit on the upright and generally 2 piston calipers have the pads mounted in the caliper, they need to be fitted to an AUII style upright.
I thought they would fit due to the fact the series one TE50 and TL50 had these brakes. Does anyone know?
Try asking au^dude, he's in the process of doing the same thing.
#6 | |||
Look this what I'm gonna do. I have the calipers and stub axles. Just need to get some 330mm Disc and i will install them on my car. They will sit at the back like the Standard Au1 do.
What is the stub axle exactly? Is that the hub, or are you referring to the upright? Do you have the upright au^dude? Cheers.
Yeah the upright.
#10 | |||
We salute those brave souls that enter the DARK side |
#11 | |||
Miami Pilot
![]() Join Date: Jan 2005
#12 | ||
XB in parts...
This may be a stupid question, but what is the "upright" technically called. Is there a proper name for it or is that actually it ?
Daily Driver 2019 Ford Escape...looking for XR6T's. |
#13 | ||
Hey fellas,put a set of brembo 4spotters and 338mm rotors on my TS50 rep,(AU1 XR8) last week.
you will need lower controll arms,uprights with stub axels-with hubs,sway bar and all nuts and bolts.make sure the sway bar you get is of the same type of motor that you have fitted.I6 and V8 are different.I had this problem.FTG sell complete kits to suit. All of these parts were available from AU2-BA and maybee even BF.my gear came of a BA mk2 and bolted up no dramas exept for the sway bar.difference in braking ability and consistency between au1 and brembos or even t series is like apples to oranges.good luck. |
#14 | ||
The only thing I can think of that the stub axle is attached to is the tie rod end of the steering and the upper and lower control arms. Mabye this is what they call an upright?
With all the drama in fitting Brembos or anything else from AU2 upwards might be cheaper and less work to fit some A P Racing as they have a setup for AU1's. There are not too many choices for us Ser1 owners!
#15 | ||
Dunno about AP Racing being a cheaper option, I haven't seen any of their kits for less than $2k. If I'm wrong please correct me, as I'm still on the hunt for the best upgrade package for sub $1k.
#16 | ||
Boost Addict
do a serach i did that conversion 4 years ago and did a write up
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
#17 | |||
Remember seeing a pic of those 300KW AU's from W.A. (I think), both the 2 door & 4 door had Brembos fitted to the rear of the front wheel, but apparently Brembo do not make a bracket for Ser1,so how did they fit them?
#18 | ||
I can do the upgrade to standard BA front brake setup for under $500 if I do the labour myself.
#19 | ||
Tickford rotors are 329mm. So don't go getting a 330mm, or it might not fit.
AUIII Falcon Forte, with SIX Appeal |
#20 | |||
Miami Pilot
#21 | |||
#22 | |||
Miami Pilot
#23 | ||
Boost Addict
its not legally possible to modify the AU 1 upright to suit AU2/3 & BA setups, as they are a cast 1 piece and have no provisions for brackets or bolt hohles, let alone cast brackets facing frontwards like AU2/3 BA do.
#24 | ||
You cant physically fit a larger than factory rotor on an AU1 upright (it is the part that the steering tie rod bolts to,joins the upper and lower control arms and holds your hub,complete with wheel bearing and wheel studs.
Look at it this way,AU1,no one really deals with the front brakes on these because they were poverty pak taxi brakes.ford were stupid to even fit them to the i6 let alone their flagship "performance model" xr8. If you swap to AU2 > you have more aftermarket support for different compound of pads,rotors,swaybars from various manufactures,and you have the option to fit up to 380mm rotors under 20" rims...you can put on the two piston factory calipers with factory rottors or up to the fpv spec 6 piston brembos.How fast do you want to go,how effectivly want to stop it.I know the gut renching felling of grabbing the brakes deep into a corner after two or three hard applications with the chassis fully loaded up,tyres on the edge of their limit,and knowing uv only got compression braking helping to wash of some speed....Not very nice at all....1st thing,number 1 thing if your going to drive hard,or tow some monstrosity,make sure you know you can pull it up.you will never look back and will be quicker for it.just my 2 cents |
#25 | ||
Oh yeah,call Marin at fordpro smithfield sydney.you will be quite suprised as they quote half the price of ftg for the stub axes,control arms etc...cheers fellas
#26 | |||
