Old 14-04-2007, 09:33 AM   #1
335JET
@jas_23_
335JET's Avatar
Default what is this part called
The piece that all the badges are stuck onto.
And how hard is it too remove off the car. cause im gonna debadge it but i'll need to fill in the holes.
335JET is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2007, 09:51 AM   #2
XR Martin
XR Martin's Avatar
Why do you need to remove it?
Pull badges off, sand down area around the holes to bear metal then weld up holes. Grind down excess weld, sand and repaint.
Not sure on the exact name, but id call it a rear sill panel.
EDIT
I dont even think they have holes anyway do they?
2004 BA wagon RTV project.
Old 14-04-2007, 09:56 AM   #3
335JET
@jas_23_
335JET's Avatar
yea they got holes, i pulled off the futura badge and theres two holes behind it, and i assume there would be with the ford badge.
If its easy to remove than i'll just buy another one and respray it, rather than do it all on the car.
Old 14-04-2007, 10:07 AM   #4
RUQ1KA
Formerly mad_ed_wagon
Im not sure how it is with EF/L's
But on EA sedans that i have owned i remember that panel was welded to the rear QTR
would be pretty big job to remove if it was welded in i'd say
2004 BA FALCON XT/GHIA WAGON
Build thread coming soon!
Originally Posted by RogerCordia
I had two cordias but recently i sold one of them so that leaves me with one cordia which i have now but i wouldve had two if i havent sold the other one.
RUQ1KA is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2007, 10:12 AM   #5
XR Martin
XR Martin's Avatar
Yeah its welded in. The cost of a new panel alone would be more than that to fill the holes and repaint.
Old 14-04-2007, 10:16 AM   #6
335JET
@jas_23_
335JET's Avatar
yea i may have to do it as you said, on the car.
Old 14-04-2007, 10:37 AM   #7
I6T5
it's called the beaver panel.
I6T5 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2007, 11:10 AM   #8
NZ
NZ's Avatar
That peice is bolted on.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2007, 11:56 AM   #9
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
Its a filler panel, Its bolted on and the bar needs to come of to get the panel of.
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2007, 06:35 PM   #10
sphell
sphell's Avatar
Yeah it's bolted on. It's a piece of **** to take off. Remove the bar and you will see the screws, just undo them and pull it off. There may also be a screw behind each tail-light iirc.
sphell is offline   Reply With Quote Multi-Quote with this Post
