does anyone know a way around these, are there chips available etc ??
my car has been on the dyno twice in the last 2 weeks, and hits the limiter... there is no way in hell i will be doing over 170 on the streets, its purely a dyno thing. |
Just slidin'
Here is what I posted to another person who asked a similar question:
Im going to show pics of the result of taking off the speed limiter. They are from another site, but I think it is extremely inportant to show them. http://fordmods.datamine.tk/gallery...ge=IMG_4523.JPG http://fordmods.datamine.tk/gallery...ge=IMG_4521.JPG http://fordmods.datamine.tk/gallery...ge=IMG_4528.JPG http://fordmods.datamine.tk/gallery...ge=IMG_4538.JPG Complete tailshaft failure, took out, the shaft (duh!), gearbox, exhaust, pobaly other ****** too, yet to see. Plus for some reason both airbags deployed. Let go AT 192 KPH. So there you go, Dont remove the limiter unless you change the tailshaft.
MD Mondeo - For the family
NP Pajero - For the adventure |
Spin 'em Habib !
Links dont work, but looks bad !
AU2PWR |
hmm not unless you like a chick with a whip lol..
hmm i didnt think that side of the equation.. |
not here much anymore
180 speed limiter in your ute given that its an auto and a ute. sedans got the bumped up limiter but utes are set at 180. mine is removed thru the edit and i have had it up to 190 but the tailshaft starts crying foul.
2024 F150 XLT
has anyone looked at different tailshaft setups/ cost ?
#7 | |||
And if you ever sell the hardcover off that ute let me know ![]()
2024 F150 XLT
the xr's had alloy tail shafts didn't they? But best bet is to get a two piece tail shaft.
#9 | |||
2024 F150 XLT
#10 | |||
Yeah true but a lighter tail shaft is spin a lot smoother for longer isn't it? |
#11 | |||
2024 F150 XLT
#12 | ||
so whats the deal with the one that let go at 192 ?? just plain unlucky ?? i dont want to push it past 190.. just to see what it makes up there ;)
#13 | |||
i was actually thinking about upgrading the hard cover.. the new BF ones with the bulge look hot ![]() |
#14 | ||
had my au doing 220ish on the dyno hasnt missed a beat yet.
#15 | ||
My last dyno runs, the ute was hitting 199 and no noise or anything, no vibrations etc, very smooth, and as i was driving it on the dyno i wouldve felt anything abnormal...
All depends on the car, condition of components etc, some are good, some are bad... |
#16 | ||
thorpe told me my tail shaft was fully sick. if your worried get it balanced.
#17 | ||
not worried.. just looking for answer on where my 30 kw's went
#18 | ||
we worked it out... and 162 from a 250kw engine.. minus the 30 odd percent loss from automatic tranny.. i am loosing 32 kw's somewhere.. even phil said he has had this ute at 175
#19 | ||
why are there runs in 2nd and third. mixtures are 11:1 whats goin on there.
were the last runs green and red |
#20 | ||
green and red are 2nd gear i think ( the first two) .. and the last two are third, because he had to build up speed to stop it from kicking down into second..
i think the second gear runs where checkin afr's, he also checked timing.. and it was at 25 deg. base was locked in between 12-15 |
#21 | ||
pink was last.. and blue second to last
the 11 Afr's is the ecu realising its wide open and dumping fuel as a saftey to keep lines cool etc... so ive been told. |
#22 | ||
Got to love these chips... only tuned for better AFR's at WOT, and a quick touch up for idle...
#23 | ||
go the chiptorque :(
#24 | ||
the AU has 2 speed limiters one is in the ecu at 180 the other is at about 190 when the tailshaft self destructs and the car stops
#25 | |||
GT-P With An Ego
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, custom billet parts, beginnings of a stereo, much more - 340awkw. Ford Performance Club of ACT |
#26 | ||
it's el/ef ?
#27 | ||
GT-P With An Ego
1998 EL (so a late one).
#28 | ||
Just slidin'
Thanks data mine. I thought theyd work, they worked like a couple of weeks ago.
#29 | ||
Couldn't you run the dyno in 2nd instead?
Mine has an aftermarket LPG system, and out of curiosity I've pushed her to 190kmh with out any noticable vibrations than 170 etc. Accidentally I've also spun it out to 5800/5900rpm in first at over 100kmh so I guess the LPG can also over ride the factory 5600 limit. |
