Old 18-06-2007, 01:11 AM   #1
sprjenkins
Spr Jenkins
sprjenkins's Avatar
Default 6 Throttle body manifold
Is any one running a 6 throttle body manifold? I know RPD do one for $1500, and I was wondering if anyone ran them on their E series and reckoned it was worth the cash?
-Before Chuck Norris visited them, they were called "The Virgin Islands" Now, they're just "The Islands"
-Mathematicians have found that due to the excessive amount of women Chuck Norris has slept with, it is guaranteed that he appears in your family tree a minimum of three times
-Chuck Norris doesn't sleep. He waits.
-Chuck Norris once worked as a weatherman for the San Diego evening news. Every night he would make the same forecast: Partly Cloudy with a 75% chance of Pain.
sprjenkins is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 04:33 PM   #2
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
i know someone on here has 1, not sure what they think about it but i thought RPD were no more?
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2007, 04:53 PM   #3
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
The car you may be thinking about is juliens (N/A power) car its a EBII with the 6 throttle body set up on it his car really goes great it makes a genuine 180rwkw n/a lots of work has gone in to making it as it also has aftermarket computer, vacum tank big cam, etc etc is it worth the money??? it may be a better idea to go speak to EFI hardware down in bayswater they sell individual throttle bodys and linkages that suit the e-series cars. sounds great though and really goes well.
tristan
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 05:30 PM   #4
needfordspeed
Got any more info Tristan?
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2007, 05:41 PM   #5
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
such as?
Old 19-06-2007, 05:45 PM   #6
needfordspeed
Originally Posted by ORSM54
such as?
How much?
Are they pretty much straight bolt on?
Old 19-06-2007, 08:02 PM   #7
EFendedXG
just a question with the filtration.... would you have to run socks like webbers or do you have a air box to go over them?
Old 19-06-2007, 08:18 PM   #8
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
yeah filter socks bit illegal but meh!
How much?
no idea mate i think they are like 150 per throttle, plus linkages and all the other stuff you need.so could add up to a lot more!!
but you do need a aftermarket ecu!! it wont run on the stock one!
Old 19-06-2007, 09:11 PM   #9
EF_Frmnt
EF_Frmnt's Avatar
if the distance between throttle plates and head could be decreased slightly.. and the openings bellmouthed.. these would be perfect to put in a big RB30 style/rajab/bresciani/whatever plenum.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2007, 10:22 AM   #10
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
it would be great but those plenums are $$$$, and then the benifit of the six throttle bodys goes out the window as it shill has to travel through the small throttle opening.
Old 20-06-2007, 10:46 AM   #11
EF_Frmnt
EF_Frmnt's Avatar
there would be no throttle opening if it was a custom made one.. not really a financially viable option but it would look great and pull like a train i would think.
Old 20-06-2007, 01:37 PM   #12
Felony
Wherever u go there u r
I was quoted about 1500 for the setup from rpd and just before i could give them cash they have now shut down and dont do anymore work unfortunately,
Felony is offline   Reply With Quote Multi-Quote with this Post
