Closed Thread
Old 19-06-2007, 05:16 PM   #1
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
Default [FS - VIC] someone buy my bits and pieces...
hey all..
really startin to need the dollars, think i might get more notice here...
bbm manifold off an ef: $100
EF Twin Thermos: $100
Smartlock Bypass Module - $100
EL XR6 Manual ECU (brand new from ford) - $600
EF Alternator (110 amp) - $90
EF P/S Pump - $60
EF AirCon Compressor - $50
various bits and pieces just ask... i have an ef xr6 motor i think i will be keeping...
pickup in pascoe vale...
santo
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline
Old 19-06-2007, 05:26 PM   #2
needfordspeed
Try eBay man, you'll probably have more luck there!
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline
Old 19-06-2007, 05:27 PM   #3
335JET
@jas_23_
335JET's Avatar
what is the ecu no. im assuming the first 3 digits are 6TA
335JET is offline
Old 19-06-2007, 05:38 PM   #4
Sundeep
Sundeep's Avatar
Sell the car I'll buy it, it's sick.
Sundeep
Sundeep is offline
Old 19-06-2007, 06:45 PM   #5
santoitaliano
BF F6, APV SR3900
ecu is ford part no
R96DT-12A650-AC
or catch code 6TAC...
i can not stress enough that this ecu has been purchased straight from ford a couple weeks ago and has NEVER been fitted to the car.
The R in front of the part number signifies it is a ford re-manufactured unit and they will be no longer carrying them anymore. If you go to a ford dealer, enquire about this part, you will find there are 6 left in australia and they are $990 a piece.
Santo
Daily:
Bluepower enhanced.
Old 19-06-2007, 06:46 PM   #6
santoitaliano
BF F6, APV SR3900
Also for sale is an EL Air Intake setup, including airbox, filter and piping to the throttle body... need $90 for it...
Santo
Daily:
Bluepower enhanced.
Old 19-06-2007, 06:46 PM   #7
Sundeep
Sundeep's Avatar
Why'd you get it?
Sundeep
Sundeep is offline
Old 19-06-2007, 06:53 PM   #8
MADED-6
MADED.6
MADED-6's Avatar
ill take the thermos where are u.
im in werribee so if its not far ill come on the w/e.
b4 i get them they work alright yeah.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline
Old 19-06-2007, 06:56 PM   #9
santoitaliano
BF F6, APV SR3900
coz i got silly ideas in my head...
my plans were to drop in ef motor, hook up el xr6 ecu, pop a dizzy and a coil in, run smartlock bypass, twin thermos and el intake...
i put the bbm up to my current engine, ran new water pipes, bolted it up, then realised that coz i have a build plated, original unique model, lol, that i should keep it relatively stock and not go to that extent of modifications.
so now i will prolly rip my motor out at some point, whack the crank and head off the ef motor into my 3.9er keep current 3 belt setup and clutch fan and jut have a nice fresh motor...
Santo
Daily:
Bluepower enhanced.
Old 20-06-2007, 08:01 PM   #10
fairmont1998
fairmont1998's Avatar
Please use the For Sale section of Australian Ford Forums to sell items.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline
Closed Thread
