#61 | |||
My kids think I'm cool
Dave (XD351 on the forums) at A1 High Perfromance makes up the MSD leads to suit so yes, can certainly be obtained- and cheap too........ he's helped out a lot of eastern staters
2011 FPV GT 335 >My Build Thread< (Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page) BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable... 2018 Ford Ranger RAPTOR 2013 Audi SQ5 |
#62 | |||
![]() Join Date: Jan 2005
#63 | ||
it seems most of you are concentrating on the Std top guns and comparing them with other brand hi end leads as i said B4 the top gun max300 are well speced and i'm prepared to give them a go especially with the 3 year warranty on the max300
#64 | |||
#65 | ||
How much are those leads BTW?
#66 | ||
I am using a combination of Top Guns and NGK Iridiums on an AU XR8, a definate improvement over the Ford leads and plugs.
Can't compare the top guns to anything else other than the factory leads but the vehicle performs better, stronger in all gears without doubt. They seem to do the job well, no negatives at this stage, probably try another make next time like the leads from QIL. |
#67 | ||
I put some topgun max leads on my car today, I had topgun normal ones before. I tested the resistance of each lead coming off and the new max leads going on. The resistance was measured on a digital ohm meter set at 40k( the topgun site states to set at 20k, but mine was either 4k or 40k). The old topgun leads showed 3.9k-4.1k per lead, the topgun max leads were .38k-.39k. so I guess that means that the topgun max are 10 times less resistant?. I dont know anything about ohms and resistance but these were the readings I got.The top gun max leads cost $80 from Autobarn.
Red bull gives you wings? ![]() |
#68 | ||
Smile
I am agreeing with JIMTE350. The leads new seemed fine as far as resistances but I dont think theyre tough enough or made well enough. My boot and lead wire does not seem to make proper contact with the spark plug tip after removing them from the plugs just once.Trying to realign the boot so that the centre wire metallic connector gets to the to the plug makes it flex excessively and if I press any harder the too soft rubber will break the internal spiral wounded core.Its not stiff enough to push it back into position as it feels like it will break just as the photo Jim posted up.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#69 | ||
i have the Max300 and yes they made a difference the car was alot smoother. Recently the inside of the lead1 has gone all crap and wont click onto the plug, ive tried moved it around with a screw driver but i still cant get it to lock on. The rest seem hard to get on aswell. Maybe u can get replacements? so i can get a new one
#70 | ||
Totally agree with you Stav they are so hard to get back on, even after one time they are a pain in the back side to get back on. Thats problly what ive done broken something inside trying to get em on, the build quality doesnt seem strong enough.
#71 | ||
i've been Quoted $75 trade and if there are any dramas quality wise i'll use the 3 year warranty
#72 | ||
put them on today much improved idle quality seems good nice tight fit on terminals heres hoping they stay that way happy so far
#73 | ||
I haven't had a lot of experience with lots of different brands, but always find Ford genuine leads fix misfiring 6 cylinders. V8's are not so common where I work, but leads are often a problem, and BOSCH are a good bet. Sometimes the leads read within specs (approx 7K ohms per 30cm) but still short out through breaks in insulation - so resistance isn't everything.
I've also been told by good authority than Inductive Core BOSCH leads are best for LPG due to the high demands imposed by the LPG on ignition. |
#74 | ||
www.TUFFCARPARTS.com
Anyone have any experience with Eagle leads?
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
#75 | |||
#76 | |||
Low au
I have the same and cant fault the product at all
99 au xr6 8 inch dvd pacemaker extractors sport exh lowered MELBOURNE VICTORY/WEST COAST EAGLES :Reverend: |
#77 | |||
#78 | ||
I've just been getting prices and have come up with the following:
ICE 8mm - $115 ICE 9mm - $140 Bosch etc around $60-$70. At over double the price, will I actually notice any physical difference when driving the car if I go the ICE 9mm?? How's longeivity on them? I'm assuming they'll be suitable for gas too a little down the track. Thanks, Justin.
#79 | ||
Fordless
I've always used Magnecor leads they're not a cheapy but they're very good.
#80 | |||
t i c k f o r d
Not sure what difference you will feel, depends how screwed your current leads are.
AUIII XR6 VCT Liquid Silver / Manual / Leather / Momo Wheel & Shifter / Premium Sound / Lovells Superlows / Koni Reds / T3 Pursuit Rims / Pacemaker 4499s / 2.5 Inch Exhaust |
#81 | ||
Smile
Last Monday some MSD leads came my way.The build quality is awesome and I am really appreciative of the forum member who made these for me. I have not installed or tested them as yet but will do when I get a second..
#82 | ||
Well, just picked up a set of 9mm ICE leads just then. Must say they are awesome build quality, and look very nice indeed. Very friendly bunch there too. They take your details, and if you're an existing customer, they give you discounts on your next purchase.
They actually supply these leads to taxi workshops, and apparently they are getting up to 300000kms out of these leads. They've said that as long as I install them and maintain them correctly, these leads should last the life of the vehicle (within reason) in a non-turbo environment. I'm not expecting any difference in how the car drives, but either way I'm happy with the purchase.
