Just slidin'
Just a quick qeustion, not sure if anyone will know an answer.
Is the CAPA flash tuner (AU, BA, BF, Territoty) able to tune turbo Au's? I know it can do AU's but do Au turbos fall under the same category? Thanks guys.
MD Mondeo - For the family
NP Pajero - For the adventure |
#2 | |||
Back to Le Frenchy
I can't see why it wouldn't, if it can tune XR6T's to some of the power figures they put out it should be able to tune the AU similarly.
not here much anymore
yes it can.
2024 F150 XLT
#4 | |||
Back to Le Frenchy
^^^^^abbreviated version.
Just slidin'
Cool, thanks guys.
You still thinking about fitting the turbo kit to the mont are you josh.
It would make a great sleeper though...... :evil3: Pete
18 T6 Multivan 03 Ba Xr turbo 300rwkw |
Just slidin'
I know.
Its just I have most of the parts here. I just need something to run it (CAPA flash), injectors (24lb+) and some piping and then install and tune it. But then theres other extras like an LSD, and a shift kit and tranny cooler. A gearbox rebuild if it blows, and a new engine if it dies. But all that still works out cheaper than buying that GTR, lol.
I found out yesterday Magna 2.6L injectors are the same as the Ford Motorsport 24lb injectors (and I think a hell of a lot cheaper as well).
Just slidin'
Cheers mechanik, that helps a massive amount
Check it out ... I'll confirm though first ... then get you firm details.
Just slidin'
Does anyone know if the beige tops (706) fit in the au? Or does anyone know what colour injector is what, like the blacks are____lb the blues are ____lb, the etc etc..
#12 | ||
The Flash Tuner will be able to work and a forced setup how ever you will be paying a fairbit more for dyno tuning to get the same result as you would say a wolf v500 or other After market ecu you will end up paying about the same for tuning alone as what an aftermarket ecu installed and tuned will set you back as tuning a flash tune is not on the fly.
#13 | |||
Blue tops are standard fitment on all AU V8's and are 24lb.
2024 F150 XLT
#14 | |||
Just slidin'
#15 | |||
Yeah i was going to go down the same route and investigated this. You will most likely pay more than an aftetermarket unit is worth in just tuning on an flash tuner and once you make more modifications you have to do it all over again. It would be a nice cheap option but it is not the case. |
#16 | |||
Back on the road
I've got two sets of identical looking blue Bosch injectors. One set flows 39lb/hr, and the other set flows 24lbs/hr. Also...not all flow ratings are at the same fuel pressure (i.e. XR6/XR6T/F6/"Magna" injectors). Safest bet is to cross-reference the part number.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#17 | ||
Sly like a G6
Edit v's aftermarket really comes down to personal choice. My local flash tune shop reckons that when I put a blower on my AU, they can wire in a MAP sensor that measures boost as well as vacuum then edit the ECU to respond to boost (rather than just editing the existing advance/RPM/load map). This should give protection from pinging on overboost, probably more important for a turbo setup than my planned CAPA kit.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
#18 | |||
#19 | ||
Smile
Look up powerflow injection on the net.Then call them for advice. They know their stuff. They sell pumps injectors and alot of associated equipment.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
#20 | ||
Or just buy some Green tip 42lb ford motorsport injectors for $390.
#21 | ||
Just slidin'
390 each???? If thats an each price, there is no way in hell I would pay that.
#22 | ||
All up.. Cresent motorsports sells them at that price.
#23 | ||
Just slidin'
Ohh!!. I was going to say, I picked up a set of F6 injectors, 32lb, for a fairbit less than that. Then found out they dont fit....
#24 | ||
sell them, and go for the ones I mentioned.. you cant go wrong.
