Now drifting a falcon
Just had my eb xr8 manual on the dyno at the albany show and shine for the first time, i purchased my car not knowing what mods were done to it, but it looks like it still had stock heads and intake and the guy i bought it off said the guy he got it from had a cam, so there i was waiting for 165 170.....and it comes out with 188, then 190 hp and that was with 255 17's on, and i dont know if this is a big figure for torque but i got 589ftlb.............so i dont know whats in the engine but im stoked, but then again extractors, cam and intake would put out that figure would it?
thanks! wish i new what was in the engine though, its fairlyhigh for e7 heads
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
So whats that in Rear Wheel Kilowatts?
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
14.915 @ 151 KPH
well done!!!
:evil3: 96 EF2 Futura I6 Auto :evil3: EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's ![]() ![]() ![]() |
#6 | |||
141.7 atw...... is 589ftlb big in torque?
14.915 @ 151 KPH
ok 141.7 it is then LOL, sorry i cant help with the torque sounds good though. im geussing it is around 450nm @ engine
What's green is gold
I just used the mr2 unit convertor,
589ft/lb = 797.67 Nm I thought you had to get an engine dyno to get accurate Torque readings?
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
#10 | |||
14.915 @ 151 KPH
#11 | |||
460hp + manual = fun
BA XR6 turbo, blood orange, 6 speed , mal wood option 3+ clutch, fg gt style 19's , xr8 bonnet, no spoiler , de-badged , sunroof , leather , premo, fpv wheel, plazmaman 1100hp cooler, plazmaman hot + cold side piping and intake, x force exhaust, 460 rwhp and more.... |
EL Monty Ghia
Torque is multiplied/divided by the gear ratio, diff ratio, and wheel rolling diameter. You need to take all those into account to work out what it would be at the engine.
'97 EL Fairmont Ghia |
#13 | ||
EBII XR6
Not a bad power figure mate ;)
DEVLXR
#14 | ||
Professional Mouse Jockey
With that rwhp figure at a rough guess it would be making about 180kw at the flywheel and about 400Nm or roughly EL or AU XR8 type power.
Not too bad. Would be fun to drive I bet!
Isuzu MUX for towing horses - currently no Fords in the stable Time flies like an arrow; fruit flies like a banana. Groucho Marx
#15 | ||
yeh a el2 xr8 got 185 atw same say so yeh 185kw to 190kw at the engine considering the wheels it was spinning......... no idea what torque in newton metres at the engine.. but a 338 rwhp vp 5ltre on nos got less torque on the same day.....?
#16 | ||
Yours is quite healthy,I put my Sprint a dyno and it pulled 228.2 hp (170kw) at the wheels! Well i think it it's great!(cam,extractors,full twin exhaust,hi-flow cats,shaker,pod filter) but i want MORE!!!!
#17 | ||
Like EF Futura said, the torque figure is actually tractive effort and is a product of the gearing. The VP was probably run in a different gear or had different gearing. Or something went awry somewhere anyway. It would have about 400Hp (298Kw) flywheel judging by that rwhp reading, so I would imagine it would have something like 550Nm flywheel torque. Or similar to Boss 290 or 6 litre HSV power.
With 141.7Kw @ the wheels meaning roughly 180 - 190kw flywheel would mean that the flywheel torque would be around 400 - 420Nm judging by other windsors making that power. I believe the 185Kw windsor makes 412Nm, the 200Kw is 420Nm and the 220Kw makes 435Nm torque, factory specs. Sorry but there is no way it's making anywhere near 589lbft (798Nm) at the flywheel let alone the wheels. Thats the realm of hipo forced induction cars like AMGs or big capacity engines like the Chevy 7 litre V8 or Viper 8 litre V10. The Boss 290Kw engine only makes 520Nm (around 383lbft) flywheel. But like I said earlier, in the light weight EB body 180Kw would be great, especially as a manual. I imagine it's a fun car to drive. I've got about 235Kw and 500Nm but with an auto and the extra weight of the BA it probably wouldn't feel as quick as your car.
#18 | ||
Boost is here!!
Yeah the torque figure is definately way out, i believe you have to set up the dyno to your car (i.e diff gears, tyre diameter) and run in a 1:1 gear ratio (manual T5, 4th gear). Mine with all the mods below made 330ft/lbs of torque at the wheels.
As stated above it would be quite a nice car to drive being in the lightweight EB body. My ute before all the major mods put out 211rwhp, that was std 185kw motor (i.e E7 heads and explorer intake), pacemakers, twin 2 1/4" dumped at the diff, K&N panel filter and BPT 3pc underdrives. Was pretty happy with that and was still quite fun to drive, but its a hell of alot more fun now ![]()
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
#19 | ||
Yeh it is quite enjoyable to drive, lays a decent skid on the pad too
yeh im thinking explorer manifolds, maf, then some nos will do the trick..... wanna get over 200 rwhp na, 300 on nos..... |
