Old 03-08-2007, 11:11 PM   #121
ryanjay
what kind of power increases do you think i should expect with getting a cam, dyno tune and the edit from JMM? Because judging by the increases that i got from what ive done so far, mabey i am expecting too much? Ive got 4499 pacemaker extractors, big snorkel, hi flow air filter, 2.5 redback cat back. And in all honesty there hasn't been a huge increase in noticeable power.
ryanjay is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2007, 11:04 PM   #122
mrs302au
Draggin Queen
jus read through the thread and was looking for an xr8 till we found our monty....came lowered on 17's with te rear wing and slight kit....5 litre...all we've done so far is fit extractors..$250, and remove the shitty pod filter and put a std airbox back in with a k&n filter $30....next is the removal of the rear muffler and putting in a straight pipe with nice chrome tip.....other mods will be done after my own car is finished...this is the wifes car, hence the name MRS302AU
mrs302au is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2007, 11:23 PM   #123
sly
Sly like a G6
sly's Avatar
Originally Posted by ThoR_
there is a guy on you tube who put a video of his XR6 VCT Auto.....0-100 and it poped out about 10-11 seconds to 100 maybe more. I said there must be something seriously wrong with it. My old commodore 202 was quicker! Maybe he has a dead map
The best value performance enhancements I've done have been to replace a dead TMAP and collapsed cat. My advice to anyone looking to spend money on mods is to first make sure you're getting stock levels of performance. Otherwise the money spent on mods will not be worth a pinch of the proverbial. My $0.02.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2007, 08:52 PM   #124
V8falcons
V8falcons's Avatar
Originally Posted by JC
But it does bugger all on a stock engine.
Was bored today,(Home alone for the weekend)
So I covered the 85mm hole I drilled in the lower section of the AU airbox today to see any differences,And fitted a 90mm PVC peice(testing only) after the airbox up to the flex elbow and after just a short drive up to the shop it has seemed to have lost some low range power/ torque.......
I will drive it for a couple of weeks and see what the fuel economy does :togo:
Im still deciding what Im going to do with the wagon at this stage it will stay a 4ltr 6cyl I just want more torque out of it with out loosing fuel economy,if to make more power means to use bucket load of fuel then really it makes more sense to slot a 5ltr under the bonnet and then start playing.???????
All Ive really done is 2.5" exh,tickford big mouth,and ram plate from the grill,big hole in the air box(yes it does make a differerence)
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 12:03 PM   #125
No Judge
That's Numberwang!!!
No Judge's Avatar
It'd be interesting to see if covering the hole or the 90mm PVC has caused the loss in bottom end power/torque....
www.aufalcon.com.au/only1
FAIRMONT GHIA: SO GOOD, THEY NAMED THEY NEW FALCON AFTER 'EM
Originally Posted by xr6 ausome
Nah the roads to high, your car can never be to low lol
No Judge is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2007, 07:52 PM   #126
daz_
Any updates?
daz_ is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2007, 12:38 AM   #127
big dano
rice hunter
would it be worth getting the air filter from ebay or just fork out for a new one?
big dano is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2007, 08:21 AM   #128
falzoony
Rockin '67
falzoony's Avatar
You can buy a new one from ebay, which is usually cheaper then the shops.
BA XR6 Turbo
'67 XR Wagon
falzoony is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2007, 11:14 AM   #129
Cespenar
Huh?
Hi, all,
I want to get the better airflow for a standard Ghia motor. I was wondering if somebody can give some details of material for the change to the airbox to intake manifold for me (and others who don't know) and how to go about it.
Great ideas in the forums mates, but I for one need detailed instructions.
A big please for some info'.
Regards from cespenar.
Cespenar is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2008, 02:32 AM   #130
GSH
AU2 XR8
GSH's Avatar
I have a AU Series 2 XR8 Auto.
I need to clear up some things.
Will a shift kit make me quicker?
A cam is 1g installed? I got quoted 4g installed.......Im in W.A....
Also i know these meat heads around just put on gear drives for sound. But do they actually do anything performance wise?
WAX `EM AUTO DETAILING
PERTH W.A
0406 553 226
GSH is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2008, 10:43 AM   #131
SSD-85
Good morning to all, since this is the perfromance mod thread i thought id just ask in here instead of starting a new one: forced induction on a vct xr6, is it worth it? turbo or blower? how is reliabilty and longevity of the car affected? i know there must be a thread on this somewhere but alas, i cant find it :( if theres anybody who has experience on this, any thoughts would be greatly appreciated
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2008, 06:39 PM   #132
blackers10
blackers10's Avatar
WeHaveIgnition .. the search button and also the forced induction section are there for that sort of question lol..
ive been told many times that hte VCT should be even BETTER on boost ..
supercharger is cheap (the new Raptor kit seems a good buy)
but isnt as expandable as a turbo setup is.. (most people use hte Snort Performance kit)
the engines can take boost stock (bout 9psi i remember hearing(with enough fuel mods ie rising rate fuel regulator or similar)
but to do it properly your looking at 10k (maybe cheaper if you can built it your self rather than a shop and or buy 2nd hand parts)
there is several BUILT(internals upgraded as well etc) turbo falcons(of the AU and earlier variety) pushing good power and going for years still
Old 04-01-2008, 08:29 AM   #133
SSD-85
Thanks for that blackers10, i'll sift through the forums and check it out
Old 06-01-2008, 07:04 AM   #134
Mechan1k
Mechan1k's Avatar
There's a red XR6 VCT that had a Snort Stg 3 kit fitted to it .... and boy does that thing produces mountain-loads of torque ... nice and easy to punt around as well.
Longevitity comes down to the driver and the tune.
When putting the boot into it (not that you really have to) ... traction becomes a REAL issue ... it has been run once at WSID that I know of and the owner only managed a 12sec 1/4 time .... due to excessive wheelspin on launch (no practice) ... and lots of wheelspin during gearchanges.
Old 10-02-2008, 08:23 PM   #135
aussiemart
aussiemart's Avatar
1 Very slightly but it would probably only just show up on the quarter mile, and would be very lucky to go a tenth quicker, but it would feel better to drive and the auto should last longer.
2 Being a mechanic i would have thought around $1000 no more than $1500 depends on the cam and if you need to get an tuner etc.
3 Top race engine builders don't use timing gears, if they don't use a chain you will find they use a belt. a good quality chain is all you need for most aplications.
Cheers Marty
aussiemart is offline   Reply With Quote Multi-Quote with this Post
