#61 | |||
Is Ford, Is Good
Displacement: 0.455 cu in (7.5 cc) Bore: 0.866 in (22.0 mm) Stroke: 0.772 in (19.6 mm) Practical rpm: 2,000-17,000 Output: 1.65 hp @ 16,000 rpm Weight w/muffler: 17.2 oz (489 g) Includes: #A3 glow plug, E-3010 muffler Requires: glow fuel, prop Recommended Props: 10.5x6, 11x6-8, 12x6-7 It has Even bigger props than you are talking about, i think you have your facts wrong
ef futura with fairmont mods. license in less than 2weeks. |
#62 | |||
i'm baaaack....
i have been flying for 13 years. and have been using OS motors the whole time (tried others wasn't at all happy with them). there is no way in hell you could get a stock 46AX to turn to 17,000 with any of the props reccomended. not unless you geared the shaft to reduce prop RPM. these engines just dont rev like that, they aren't like the little car motors at all, glow tempts, combustion chamber shape, ring (or in this case piston) to liner clearence isn't as fine, also there is more load on an aeroplane motor then on a car engine due to the weight of the prop, gravity, pitch etc |
#63 | |||
i'm baaaack....
#64 | |||
Is Ford, Is Good
#65 | |||
i'm baaaack....
put it to you this way (might make a bit more sense), if you pick a plane up, and let go of it, what happens? falls straight onto the ground and most likely breaks. but if the plane has an AIRSPEED of say 30km/h then yes it will fly, but the prop has to keep it going that fast hence load) another reason to hold it back from revving is the weight of the moving parts, 2.9cc is more then 1/3 of the engines size which means there is probaly an extra 20% minimum internal weight added, the mass of air/fuel the piston has to compress is higher which means more work for the engine, also what stroke does your motor have? also, as you said, you have a GEARBOX, giving you multiple drive ratios to work with launching, my RC truck is only 1speed and it launches like crap. an aeroplane has only one drive ratio (99% of the time anyways) and that is 1:1 also aeroplane engines are not designed to rev there tits off, they need the bottom end torque to get the plane moving and keep it moving. your engine is designed to scream mate, not like aeroplane engines which are designed to have more bottom end as i said. Last edited by XCSEDAN; 28-01-2008 at 12:53 AM. |
#66 | |||
Is Ford, Is Good
#67 | ||
They all look great, I have a collection of Losi cars at the moment a Muggy, LST2 & a Eight buggy that I had to build. We are also building a track in the next month will post some pics of my small fleet soon.
Has anyone had any experiances with the TL Muggy?
2006 BF GT, Lightning Strike & Orange decals, 6 Speed Tiptronic, Leather trim, Sunroof, Momo wheel, Tinted windows, Reverse parking sensors. :eclipsee_ |
#68 | ||
i'm baaaack....
i'll have a look mate ;)
is this your truck btw? http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=45914 |
#69 | |||
Is Ford, Is Good
#70 | |||
Audi S3
nah had heaps of troubles with those things that attach onto the axle's through the diffs. i fixed them so there is no chance them coming off again. the close up of the belt, that belt is fine, i think the issue is with the long one that goes through the car. its on the gears/cogs so i dunno wtf the problem is. ill keep perservering.
#71 | |||
#72 | |||
The Eight buggies are awesome - I was almost going to get one before I decided I really wasn't that into racing nitro stuff and was happier to just have a fang at a BMX track now and then.
BLUFGX | 2015 Kinetic FGX XR8 KPM Oil Breathers, Koya SF06 20x9/20x10s, Michel Pilot Sport 4S 245/275, G6E Chrome Front Grille/Foglights/Window Trim, Disabled Bi-Modal - More to come! |
#73 | ||
Tricolore Tard
![]() Join Date: Dec 2004
More RC then i can count
![]() Truck I have a Savage 4.6SS - http://www.stfocus.net/photography/r...cing/savage46/ Rest of my Cars - http://www.stfocus.net/photography/rccars/ They range from 1/8th Trucks, to 1/46th Scale Micro Losi's ![]()
#74 | |||
Is Ford, Is Good
#75 | |||
i'm baaaack....
#76 | ||
Just brought my self a 1/8th scale Savage 4.6 'Big Block'
.28 ci Havent run it...yet. I have a few 1/10th cars, never a monster truck before, they are BIG. Also a few of the rest of the family...
#77 | ||
BA GT-P Owner
I have a 1:10 truck that i have built but havn't fired it up to see if it runs or not and i have a one of the pirtek 1:10 cars. Also have a unpainted XY 1:10 top but i'm not sure how to paint it.
DAILY DRIVER/TRACK CAR BUILD NUMBER 006 299.5 rwkw's 12.74 @108mph ON MT's ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
#78 | ||
OLD - EL Fairmont 97'Heritage Green,tickford bodykit, Tickford Gas, Pacemaker extractors, 2.5 exhaust,Blue and Red LED dash, Mirror Tint, Superlows all round, with 18' Advanti rims NOW T5 conversion |
#79 | ||
Heres my losi xxx-t and my traxxas e-maxx.
![]() ![]() Im selling them if anyone is interested? The emaxx has had a few updrades in the stering servo , bulkheads, shock towers, tires, center drivetrain. The losi has had heaps of upgrades, main ones gt-x speedo, high speed stering servo, reedy krypton 10x2 modified motor, and nearly everything graphite. heaps of extras |
