Old 03-06-2008, 11:10 AM   #31
james22
With da Warlords
james22's Avatar
If you can, place the positive charger clip onto your batt terminal. Not the wire, that way you KNOW you've got a good connection. Better that way
If you put the positive onto the terminal and the negative onto earth and your charger is plugged in, it will be charging. But it'll take a while. Patience grasshopper lol
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2008, 11:14 AM   #32
sednwol
sednwol's Avatar
Did that half an hour ago. I'll give it a few hours and hopefully it should have worked.
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2008, 11:34 AM   #33
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
What sort of charger do you have? can you set it to fast charge or trickle charge? that alone makes a heck of a difference...
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 03-06-2008, 11:41 AM   #34
sednwol
sednwol's Avatar
It's an Arlec 12v. There's no settings. BTW can you buy the set up the RACV use: a 9 volt battery plugged into the cigarette lighter?
Old 03-06-2008, 11:54 AM   #35
InfernoSR
InfernoSR's Avatar
Yeah... i think both DSE and Jaycar do something like that...
Old 03-06-2008, 03:12 PM   #36
sednwol
sednwol's Avatar
LOL, just had the RACV out and the battery is a dud! It's just over 12 months old and fortunately under warranty. Thanks all for your help.
BTW memory minders (9 volt battery set up) can be purchased from Repco for $11.50. I bought one for next time :togo:
Thanks all for you input.
Old 03-06-2008, 03:24 PM   #37
james22
With da Warlords
james22's Avatar
Ahh no wonder, That'll do it lol.
Well next time you know how to go about it don't ya...
Have a good one! :-)
Windsor Warlords
AU III XR-8220
Old 03-06-2008, 05:55 PM   #38
sednwol
sednwol's Avatar
To top it off the guy who installed the new battery stuffed up the memory minder and I had to drive to Ford to get the code and reset the radio. Knox Ford here in Melbourne were great, no charge and very helpful.
When I first drove the car after his stuff up the auto-transmission change up was all wrong, sorted itself though as the ECU got it's act together.
