I've seen a few threads a while ago where some people have fitted B-series pedals to their AU. I've got an auto and i'm wanting to put the B-series auto pedals onto it. How do I do this?
Also how do you remove the accelerator pedal off a BF?
2007 BF MKII XR6 CONQUER |
do you mean the alloy pedal covers or the whole pedal?
Everything always works out when you just do whatever you want and don't worry about the consequences. see my ute here AU parts for sale |
Sorry, I should've mentioned that. The pedal covers.
Barra Turbo > V8
Then your VCT will be much slower then a HP with B series parts
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ -2022 Hyundai Tucson Highlander Diesel N Line |
LG did this, it involves cutting the pedal mounting point I believe, do a search, it's on here somewhere...
Accelerator pedal is a real pain to get off, I destroyed one on an XR8 getting the old plastic one off to put alloy ones on. Good luck. |
#6 | |||
So LG did it? He might have a how-to then, he usually does which is really useful. Thanks for the heads up.
not so stock
[QUOTE=51RTE]Then your VCT will be much slower then a HP with B series parts
Liquid silver AUIII XR6, BA scuff plates with Tickford inserts, proudly displaying AU falcon.com stickers, lowered, K&N panel filter with wide mouth snorkle, 2 1/2 exhaust and hi flo cat, Illusion mags, slotted and drilled rotors. Next mods: extractors |
#8 | |||
Barra Turbo > V8
[QUOTE=fipcee]
Ah damn I mixed up LG with GK, Gk always makes the how-to's when he does stuff to his car. Anybody else done it and would like to share how?
http://www.fordforums.com.au/showthr...ight=ba+pedals
http://www.fordforums.com.au/showthr...ight=ba+pedals http://www.fordforums.com.au/showthr...ight=ba+pedals http://www.fordforums.com.au/showthr...als#post653399 Does my search function work differently to yours? |
Tickford Tough
There used to be a 'how to' guide on here somewhere. When I did mine I had to grind down the edges of the brake pedal a bit so the alloy cover would fit. Then drill a hole for the small hex bolt. From memory the accelerator pedal cover also required a little filing down to fit. Both pedals were stuck down with Sikaflex too so they never come off.
Sparkling Burgundy T1 TE50 Build #027 - SOLD |
#12 | |||
Yep I took a look at the thread links mattp gave me and JC did a full how to on it:
#13 | |||
Audi S3
