EA FALCONED
how can i remove the computer there is a plastic screw and like a rivet holdin the computer in with the ground to it what would be the best way to get it off need help asap trying to wire up shift kit
1989 EA SVO FALCON Restoration attempt SVO wheels 16x7 & 16x8 SVO MOMO steering wheel SVO rear spoiler SVO dash cluster SVO RECARO trim SVO headers SVO grille Sounds good pity it hasn’t ran in 3 years
Afterburner + skids =
![]() Join Date: Dec 2004
Drill it out. Replace with new screw.
EA FALCONED
so i can do that wasnt sure if i could do that i was thinking to much shock to the system you know what i mean
Did it with mine, was all good.
EA FALCONED
spose u didnt have el chepo drill bits that bend or break every time
(new years resolution stop bein a cheap ****)
EA FALCONED
i have a old street ford mag with the write up of how to put in a shift kit but on further looking i cant find pin 81 there is no wire there has any one wired one up i could use help
Tyre Shredn
yer man just done my brothers this weekend, easy as, 30 min max.
pin 81 is a solid green wire start from one side and you have to count each pin, i think 79 is the first one on the top left so should be 2 over from that. from memory. the harder one is pin 71 cause its right in the middle almost, just triple count the pins to make sure you have the correct one. i like to be triple sure and for the rivet just drill it out and replace it with a screw, and just rip that plastic screw out |
EA FALCONED
yeah all good pretty quick job to
