Old 04-03-2009, 06:41 PM   #1
JMO
JMO's Avatar
Default Remove cables from transmission
Could someone tell me how to remove the four connectors on the side of the transmission? The wires are coming from the engine bay. There is a large white circular one, and three smaller ones.
Cheers.
EDIT: Or if someone knows how to remove the lower half of the BBM. The small black bow that has a bunch of wires under it and a bolt on top doesn't want to slip through the gap between the runners.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 07:17 PM   #2
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
They are always a pain, usually blocked up with mud/tar etc so wont release properly
Try some WD40 and pick out the muck with a small screwdriver or similar
The large round connector has 2 flat bits on the sides squeeze these together and pull it apart
The smaller plugs into the inhibitor switch have a piece to depress before pulling back and the speedo cable one just pulls apart
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 08:29 PM   #3
JMO
JMO's Avatar
Thanks for that Jastel. I finally managed to get them off. The concrete is FREEZING!
