Old 06-04-2009, 03:36 PM   #1
eXi7w0unD
eXi7w0unD's Avatar
Default auto gearbox question
if i go down a hill and put the gear in nutral is that bad? cus apparntly they guys are work beg to differ and it will overheat and stuff the gearbox...
and in an auto can u use gears say pretend it was a manuel? like take of in first then put it in 2nd, then 3rd when i feel its nessessary to change then back down gears when i come to a stop. will this in the end blow up or ruin my auto gearbox?
i won.
eXi7w0unD is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2009, 03:57 PM   #2
blueoval
Critical Thinker
blueoval's Avatar
You know I sometimes use my auto like a manual when needing to come to an abrupt stop. I didnt think there was any detrimental effect. I'd like to know too if this is bad also.
Putting the gear in 1st and manual shifting up gears I thought was fine as well. I mean all your doing is choosing when you want the next gear to be selected. right?
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 06-04-2009, 05:33 PM   #3
Dauphin
Irregular member
Dauphin's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Endless work keeping the AU.com.au web site happening
If it was designed to do it, and allow it, then do it. You won't hold onto the same car forever, right? Enjoy it while you have it. But practice common sense. Don't manually shift down to a gear near its max speed all the time.
Keep in mind that the T-series cars with the push-button shift on the steering wheel (ESS) had some stronger internals in the auto box, so that says something. They had higher power V8s, but some people say the stock BTR 4-speed is good for a lot of power.
Some people get their BTR boxes built stronger so they can do what they want with them. There was a good thread on this subject just recently.
I've been told that manually shifting down for engine braking will kill it faster. I've also been told that 3rd gear is its strongest.
I myself frequently use 3 and 2 for braking and descent speed control purposes. The only problems I've had with my auto box is a leak over the 5 years I've had the car.
You may want to look at getting a trans cooler just for peace of mind, helps keep it running cool, a good idea if you're going to engine brake with it.
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny
My hovercraft is full of eels!
Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971).
Dauphin is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2009, 05:38 PM   #4
blueoval
Critical Thinker
blueoval's Avatar
Agree with Dauphin. A tranny cooler is a must. Heat and BTR trans dont mix. Its good peace of mind to get a trans cooler on the car asap if you dont have one.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 06-04-2009, 05:45 PM   #5
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
regarding the question about popping out of gear going down a hill, personally I think it is one of the more stupid things to willingly do while driving.
Firstly shunting it back into gear whilst the engine speed and gearbox speeds aren't matching is gonna shorten the life of the gearbox
Secondly there's always a chance you'll get a compression lock (I think that's what it's called) and spin, not really desirable...
Holden: If you cant beat them, buy them.
DoreSlamR is online now   Reply With Quote Multi-Quote with this Post
Old 06-04-2009, 05:50 PM   #6
The Monty
Just slidin'
The Monty's Avatar
I wouldnt put it in neuatral going down hills, but as for using it as a manual, go for it. It locks up and extra clutch and a sprag if taking off in first, and seriously, Ive had mine for 130 000k's and 4 years, have used it as a manual since Ive had it, 6 drag nights, 2 skidpan days and 2 dyno's, as long as you keep the oil fresh with a nice tranny cooler on it, and no stupid burnouts or stalling too much, it should be fine.
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 07-04-2009, 05:37 PM   #7
eXi7w0unD
eXi7w0unD's Avatar
is trans cooler a transmission cooler? where could i get 1 installed?
i won.
Old 07-04-2009, 06:19 PM   #8
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
yes a trans cooler is a transmission cooler. trans is short for transmission.
and a trans cooler isn't necessary unless you're flogging the right rotten crap out of it or doing some towing.
What is 100000 times more important than a trans cooler for long life under normal conditions is servicing once a year.
Old 07-04-2009, 07:23 PM   #9
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Ever notice when tow trucks pull an auto it's usually backwards with the rear wheels off the ground, there's a reason for that. Somewhere in the manual it should say that you shouldn't run an auto in neutral at any more than 40kph and not for extended distances because it'll stuff them, at least that's the way it used to be no matter what manufacturer it is. Maybe the new boxes don't have the same issue, you'd have to ask an auto trans specialist.
........ and why would you even want to coast down hill in neutral in the first place, that's just asking for trouble with no engine braking at all.
Bushbasher
MINE- AUII Forte
Old 07-04-2009, 08:00 PM   #10
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
Actually ur correct and incorrect there bushbasher, the reason u arnt supposed to tow an auto car is because there is no pump circulating fluid thru everything to lubricate it, with the engine running the transmission is pumping fluid thru all the lubrication circuits lubricating it, there is nothing wrong with putting an auto in neutral going down a hill if the engine is running, it will actually help cool the transmission rather than create more heat cause the pump is pumping and their is no load being placed across it.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2009, 01:48 AM   #11
The Monty
Just slidin'
The Monty's Avatar
Also, if you have it in neautral and are idling along, not revving it, when you put it back into drive, you wont even feel it slip in. I had to do this with my first tune, as coming to a set of lights, it would want to keep driving, so Id have to knock it into Neautral to slow down.
Old 08-04-2009, 03:03 PM   #12
eXi7w0unD
eXi7w0unD's Avatar
thanks for the help guys, i dont usually put the car in neutral theirs just 1 hill that goes up and down up and down, and if u put it in neutral it goes over these for about a kilometer hehe.
and yeah i spose i dont need a trans cooler but i want 1 cus it help never the less when i take it to qr or willowbank or even archerfield drift muahahahha
i won.
