hey guys not sure if anyone can help me but ever since i got the car (last nov) i've noticed the a/c making really weird noises, they're louder when its turned on, still there when its turned off but not as loud or as frequent. i made a video as the noise is hard to describe.
http://s179.photobucket.com/albums/w...t=LGVR0004.flv |
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Sounds like a dry / dying fan bearing .Nasty things to get to
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
thanks mate, expensive to replace?
Flairs - Truckers Delight
yes, because you need to take the friggin dash out almost. FingC of a job.
eff that then, what a lemon of a car.
#6 | |||
i suppose but i've had problem after problem with this thing, diff rebuild, new brake booster, now another brake problem i've yet to diagnose, random electrical problems, this fan bearing, and it hasn't even reached 200k yet
ah well should have waited and got an AU 2 lol |
Diff at 180k? What the hell?
![]() Join Date: Oct 2006
It does sounds very much like the fan bearing.
However, although much less likely but if you are extremely lucky (and based on your track record so far lets not get our hopes up) it might just be something in the fan duct and stuck between the fan and the duct (leaves). With a rabbit's foot in one hand cycle it through all modes floor, face level etc check by hand and with a vacuum cleaner the floor pointing duct behind the glove box and pull the fan speed controller on the firewall and vacuum clean everything out of the duct behind that.
regards Blue |
