Old 06-04-2009, 04:32 PM   #1
old fordnut
too many fords
old fordnut's Avatar
Default Debadge
Whats the best way to remove the badges on the XR8?
Daily driver 1: [COLOR=Indigo] 2010 FG XR6 Turbo 50th Anniversary, BPR CAI, Plazmaman turbo pipe.
Daily driver 2: Nissan gq patrol
Project 1: XP ute, 351W, c4, 9inch
Project 2: XBGS sedan, sunburnt orange and vinyl, original 4spd, 302C.
old fordnut is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2009, 04:38 PM   #2
blueoval
Critical Thinker
blueoval's Avatar
Eucalyptus oil.
Pour some on the back of the badge where the adhesive is, let it sit for 10-15mins. Gentle remove with fingers after. Clean surface area with bug & Tar remover.
Thats what I did with mine.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 06-04-2009, 06:23 PM   #3
Bucknaked
Bucknaked's Avatar
A group of 12 year olds. They are good at debadging other peoples cars.
Bucknaked is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2009, 07:52 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Debadging is for Bogans.
Old 06-04-2009, 08:16 PM   #5
toolchick01
Now with an AU XR6
toolchick01's Avatar
^^^ Do you ever have anything positive to say?
Stop chasing me! I don't have any donuts!
1999 AU1 XR6 VCT - Now with a momo steering wheel!
Manual - 18" Koya Race Tek's Black with polished lip - Lowered - Series 2 tail lights - Pioneer P80 Head Unit - Clarion Front 6" Splits - JL 5x7's Rear Coaxials - Clarion 4x90w RMS amp - Clarion DPX1800 800w RMS mono - 2 Clarion PXW1251 400w RMS 12" subs
Team Deck Chair Member ............ Once you sit down, you'll never stand up.
toolchick01 is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2009, 08:41 PM   #6
THR347
THR347's Avatar
Heat up the badge with a hair dryer on low heat for a few minutes. Then, use some fishing wiring and slide it behind the badge, use a sawing motion if need be or you may need to heat up the badge a little more (essentially the heating loosens up the glue). Presto! You may have adhesive still stuck to the car so in that case i would then use eucalytpus oil on a rag and apply some elbow grease. I've de-badged my xr6 and it looks very clean and mean - far from bogan!
http://aufalcon.com/THR347
THR347 is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2009, 09:49 PM   #7
old fordnut
too many fords
yeah mate and look at what you drive. :
Old 06-04-2009, 09:49 PM   #8
old fordnut
too many fords
Thx mate I'll give that a go
Old 07-04-2009, 12:19 PM   #9
Bucknaked
Bucknaked's Avatar
Hair dryer will work, but I do believe the AU1 the badges were mountedthe old fashioned way. There will be holes under the badge. JC or GK will know more on this. Just a feeling I have.
If this is the case then I don't think a hair dryer will work.
Old 07-04-2009, 12:50 PM   #10
JC
Miami Pilot
JC's Avatar
Correct Bucky (must have been a lucky guess, lol)!
The XR and Tickford badges are stuck on with no holes behind them, but the Falcon badge on AU1s has holes behind it.
Ford Performance Club ACT
Old 07-04-2009, 11:52 PM   #11
THR347
THR347's Avatar
I've actually got a S1 so i can confirm that the "falcon" badge does have the holes-behind-the-badge type attachment but it still has glue holding it on and the hair dryer technique does indeed work and i would still highly recommend using this method. See my pics on aufalcon.com, click my signature link below.
Due to the falcon badge on the S1's having holes behind it i used the normal procedure, giving it a blast with the hair dryer to loosen up the glue and then using fishing wire to pry off the badge. Of course the badge is still stuck on because it is still attached to the body through the holes in the bootlid, but this was easily solved by gently pressing the badge out from inside of the boot. It is most likely that the badge stalks that hold the badge in the holes will break but meh! Then it's just a matter of filling the holes with bog, sanding and painting! Schweet... the result? the illusion of a shaved sleeper i suppose?
Old 08-04-2009, 12:06 AM   #12
Cookie-XR8
SKID IT
Cookie-XR8's Avatar
i used a screw driver lol. only cause the car was getting painted anyway
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba
Where the boost junkies hang out -Forced Ford Forums
Cookie-XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2009, 12:11 AM   #13
slickpencil
BlueEyed Terri
slickpencil's Avatar
Few info here: Debadge Territory
Eucalyptus and Dental Floss. Thats how I did mine
slickpencil is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2009, 12:54 PM   #14
broken_suave
broken_suave's Avatar
I took the Futura badge off with my thumbnail...
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 08-04-2009, 09:04 PM   #15
webby_191189
low wagooon
Also Utes have pins in the tail gates on the falcon badge, Was going to remove mine off the xr but found i couldnt
Webby
S2 AU XR6 UTE
webby_191189 is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2009, 02:29 PM   #16
old fordnut
too many fords
I'll leave the ford badge on just want to get rid of the XR8 badge and the wings for a smoother look
Old 09-04-2009, 02:31 PM   #17
JC
Miami Pilot
JC's Avatar
Hairdryer and fishing line/dental floss is the way to go then.
Old 15-04-2009, 07:01 PM   #18
brilt9
Smile
Well i have recently debadged my BA and found it very easy, I went down to Autobahn store and had a chat to the sales guys, they suggested K+H Wax and grease remover to get the glue off from the paint and Kitten Cream polishing wax no.1 (Cuts aswell as waxes)
I simply cut the badges off using wax dental floss, but fishing line would work also, then sprayed the wax and grease remover, Wipe off paintwork ASAP as is solvent based and you dont wanna damage your paintwork, Then just applied polishing wax and wiped over a couple of times, Came up perfect, no scratches or fade marks. All up only cos about $25.
brilt9 is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2009, 01:04 PM   #19
AUIIXR8Ute
Automotive Detailer
AUIIXR8Ute's Avatar
I know my AUII ute has pins behind the Ford badge and Falcon badge.
As suggesed, the best way to remove them is to soak the area in Eucalyptus oil or bug and tar remover. Using fishing line like a saw, cut into the glue/double sided tape behind the badge and either gently pry. Don't use a screwdriver, one slip and you are up for a few dollars.
The gunk that's left can be easily cleaned and polished up.
AUIIXR8Ute is offline   Reply With Quote Multi-Quote with this Post
