A few weeks ago the missus got a new battery installed in the XR8. Since that time the idle has been really hit and miss in that it idles fine most of the time, however when you put it in neutral or park it will stall 80% of the time or idle really rough. Starting in neutral or park it idles fine. Just come back from the garage and the computer had an error code for the coil packs. Cleared the error and car went fine for a while then started playing up again. Does this mean I'm up for a new set of coils or could there be something else the problem? Is there any way in which I can rejuvinate the coils? I eventually want to put s decent set in, but can't afford to at the moment.
Also does anyone know if the AU and EF coil packs are the same?
gone fishing
I'm pretty sure that once the coil pack/s are gone that's it with them, as with the codes, not sure about that.
But i would hazard a guess that if the codes were cleared and the problem went away and then came back, I sure would be looking at the coils being stuffed and need replacing.
Cheers Whiskers |
Look at IAC valve first and give that a good clean. There are about 100 posts in this forum that tells you how to do that. More than likely thats your problem.
#5 | ||||
Back to Le Frenchy
Time for new coil packs, they only have a lifespan of 80-100k anyway. MSD ones are cheaper and better, and no EF ones aren't the same as the EF ran a distributor.
#6 | |||
Got some 2nd hand coils to throw in so hopefully that makes a difference. Over $600 for new ones! |
#7 | ||||
Back to Le Frenchy
Critical Thinker
I paid $100 on ebay for a brand new OEM unit.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
#9 | ||||
Back to Le Frenchy
Critical Thinker
oh ok. I'll go now
#11 | |||
But as RG said, get yourself some MSD coils. Your going to get bent over if you go to ford and buy the OEM part. |
#12 | |||
#13 | ||||
Back to Le Frenchy
You are correct for the I6 however.
#14 | ||
Barra Turbo > V8
I know its different but have you tried an ECU reset? Same thing happened in my TE had the battery replaced, stalled when in neutral and sometimes had to drive with 2 feet aswell.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ -2022 Hyundai Tucson Highlander Diesel N Line |
#15 | ||
where do i get some MSD packs from in melbourne and what's the part number for them? Do i need and specific leads to go with them? prefer to get msd leads too i guess. do u use 8mm or 10mm?
#16 | ||||
Back to Le Frenchy
Coil packs can be had from anyone who uses Rocket to get their parts, there were a few sets on eBay recently so check there first as they were cheap. The part number is MSD8241 and obviously you need 2.
#17 | |||
Walking with God
Resetting of AU ECU http://www.fordforums.com.au/showpos...9&postcount=85 I agree it's probably the coil packs, especially with the code occurring, however, resetting the computer and cleaning the IAC/ISC valve will not hurt you, is a good thing to do every 3 or so months and does help the car to go better. You never know, it may sort the problem! Give the TB a cleaning whilst you're at it. Cleaning ISC Valve http://www.fordforums.com.au/showpos...9&postcount=43 Cleaning Throttle Body http://www.fordforums.com.au/showpos...2&postcount=48 All the best with it. GK
#18 | ||
Yeah resetting the ECU worked for about 5 minutes, then it obviously relearnt the coil packs are stuffed. Got some coil packs to chuck in it over the next few days.
Also cleaned the ISC valve, no change. And the MAF, no change either. Must be the coil packs... |
#19 | |||
Walking with God
All the very best with it. GK
#20 | ||
Start with the cheapest and easiest, and work you way up through the dollars and difficulty from there!
