Old 20-07-2009, 06:27 PM   #1
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Speaker Screws
Sorry to be a nong
but what sort of screw type thing holds in the speakers?
What sort of tool do i need to get them out?
/inb4 pliers
Old 20-07-2009, 06:31 PM   #2
superroo
You can't stop the signal
superroo's Avatar
Memory says that they are a male torx screw, hence a female torx bit. But they may have more points than that. Been ages since I've seen them
Either way a 5mm socket works well in removing them. I may be wrong on the size thought. They may be 4mm or maybe 6mm but a small sized socket does work.
Old 20-07-2009, 06:47 PM   #3
Mr Hardware
ah sweet as. small socket it will be. thanks mate!
Old 20-07-2009, 06:54 PM   #4
data_mine
GT-P With An Ego
data_mine's Avatar
It's called an E type socket. Good hardware stores will have them.
Superroo is right, it's the other 'sex' of a torx head.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw.
2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw.
2008 SY F6X in Silhouette, custom billet parts, beginnings of a stereo, much more - 340awkw.
Ford Performance Club of ACT
data_mine is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 06:55 PM   #5
Mr Hardware
wow!
right!
thanks mate
Old 20-07-2009, 07:19 PM   #6
data_mine
GT-P With An Ego
data_mine's Avatar
I've only ever used the one. E6.
Old 20-07-2009, 07:47 PM   #7
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
mate use a 5mm socket does the job i did not only two days ago worked great.
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 08:10 PM   #8
HLC
Audi S3
thats what i used many many moons ago.
HLC is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 08:13 PM   #9
rayjaymor
rayjaymor's Avatar
5mm socket --- I'll bet my balls it's cheaper than a set of E-type sockets!
Originally Posted by blake fergo
what is the best way to do a burnout aka sitter in a 6sp manual ute with out burning clutches and causing damage to ur car ?
Originally Posted by FPV+fteT3
The best way not to damage the ute or embarass ford owners is to replace the ute with a VL commo with 15" steelies on the back and slushbox :sm_headba
rayjaymor is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 08:28 PM   #10
asizzy
+1 I agree with ya
AsIzZy
asizzy is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 09:02 PM   #11
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Pliers work as well
They are not real tight
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 10:17 PM   #12
au11futura
au11futura's Avatar
Originally Posted by Jastel
Pliers work as well
hahaha yeh true.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 20-07-2009, 10:24 PM   #13
THR347
THR347's Avatar
Yep, as previously stated 5mm socket does the trick!
http://aufalcon.com/THR347
THR347 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2009, 10:52 PM   #14
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
Fantastic news, that shall help me out this coming weekend, now off to troll the old threads for making up 6" speaker spacers for the front
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
