White Lightning
firstly can it be done hassle free? secondly will an au xr6 head yield more benefits than an e-series one?
PM me if you want
Yes and Yes, go for it, use an AU metal head gasket and new head bolts, enjoy.
are there any gains using a AU Head, beside the specs of it?
Just remember to use the AU rocker gear and cam.
White Lightning
yeh its the whole head and up. rocker gear and cam and valves and everything. thanks for the replies. my mate will definitely go ahead now.
Hmmm Gold!!!
the only thing i would think is will the EA computer be able to run the AU XR6 well enough, im not sure how big the cam is but i assume alot bigger than what the EA comp was ever designed for.
would that be a problem?
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber ![]() Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
PM me if you want
The EA cam is technically a big cam anyway, so it should cope, otherwsie source an XR ECU will make it go nicely.
Hmmm Gold!!!
the EA is non smartlock :(
NOS Induction pssssshhhhh
the au head cam will work with your computer with out any problems the cam size isnt much bigger then the ea cam.
STOKEB - 3:7 diff gears, 3inch zorst, JMM Race Series Extractors, Custom Bottom end to suit N20, AU DEV 6 Head and Cam, Cold Air Intake, ED XR6 Manual Computer with Flash Tunner, ED XR6 Fuel reg, C10 Auto, 2800stall . --------------------------------------------------- I LiVe My LiFe A bOtTlE aT a TiMe, FoR tHoSe 200 sQuIrTs I fEeL fReE.........pssssssssssssshhhhhhhhhhh |
BASS ON BOARD!
from what im told the AU head has smaller ports and valves so do it the other way round use a AU block (had a better crank) and a EL head as it flows more
thats what im told and use a JMM multi layer steel head gaskit , thin giving bit more compression thats my 2 cents
Nothing interesting to put here. |
