Old 29-03-2010, 07:40 PM   #1
eddiemonster
Default Focus Throttle Body Cleaner
Hi i have a 2007 LX Focus done 27,000km wanted to clean the throttle body i brought Nulon Throttle Body Cleaner it states avoid direct contact with electronic devices such as idle speed controls and throttle controls. It may be necessary to remove these components for correct cleaning a bit unknown to me :alien2: Do i need to do this?
My question is what is the best way to clean it and if i just spray inside the throttle body do i need to do anything else.
Thx in advance
eddiemonster is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2010, 07:54 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
I'm not an expert on later model Focus', but I have to ask the question...
...why are you trying to clean the throttle body on a less than 3 yo Focus????
I know earlier models have a coating that you should specifically not clean.....so I'd proceed with caution on this one
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2010, 08:08 PM   #3
eddiemonster
Thx for the feedback just thought it may need a clean after 3 years but when i started reading the can may give it up if earlier models have a coating sure mine does 2 thx 4 the caution may ask a dealer Cheers
