Any size difference from au s/3 forte to xr series stabilizer bar diameter . ?
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
The only thing u'll see!!
Don't waste your time, go for 30mm adjustable whiteline in front and 22mm in rear.
not sure what forte size is, s2 xr is 24mm.
cheers , yeah measured mine 24mm
Anyone know the diameter of the rear bar in an AUII forte
"not sure what forte size is, s2 xr is 24mm."
"cheers , yeah measured mine 24mm" (why isn't the quote function working?) Yeh? Only 24 mm? My AU1 forte has 28 mm. Funny they decreased the size. |
Its possible the AU1 is hollow, whereas the AU2-3 is solid..
Just a thought. Not sure how they would compare though..
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
All rear AU swaybars are hollow. My standard swaybar mearsured 23mm, whereas the whiteline item is 22mm. However the weight difference is increadable.
My car has launch control, simply BAM-BAM-BAM-BAM-BAM-BAM-BAM then select D for maximum respect, it bushfires the s**t house everytime!!! |
series 1 xr bars were thicker but all series 2/3 are the same I was told by ferntreegully auto salvage.
series 1 and 2/3 are not interchangable as designed to fit different lower control arms series 1 are old school pin and bush design while series 2/3 are like a ball joint. hope that helps. |
