Old 05-07-2010, 06:54 PM   #1
adrian k
adrian
adrian k's Avatar
Default NO power under 2k rpm
My S3 XR8 has developed a flat spot, and i mean flat spot when cold. so after letting car idle for a couple minutes each morning so melt the ice on the windows, i drive off and there is no power until revs hit 2000, i mean nothing, the more boot your give it the more it gurgles and slowly creeps to 2grand, then its off like a two stroke coming on pipe. 2-3kms down the road its fine. although it doesn't seem to have the same response from idle that it did a year ago. it does it summer and winter. Ford had the car all day Friday and can't fault it. I replaced the MAF sensor (another second hand one) at Xmas time and it behaved itself for a couple of weeks then back to the same.
Any ideas? TPS, temp sensor, squeeky cam sync, blocked jets, coils, leads, O2 sensors??
Any suggestions would be greatly appreciated, this is pis... me off.
Can stock bar HMS intake, K&N and full HMS SS zorst.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2010, 08:16 PM   #2
Windsor220
Now Fordless
Windsor220's Avatar
This may be similar to what was happening with mine a while ago. When first started, a bit up the road would die down and then come back to life. After that it would be fine.
I ended up replacing 02 sensors and the fuel filter and its been fine since.
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2010, 08:33 PM   #3
adrian k
adrian
adrian k's Avatar
Now in English
CAR is stock bar HMS ......
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
Old 06-07-2010, 08:48 AM   #4
RG
Back to Le Frenchy
RG's Avatar
Now in English
I understood that anyway lol.
I'd be replacing the o2 sensors and the fuel filter for a start. How many k's has it done?
Old 06-07-2010, 09:15 AM   #5
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
Now why does this not surprise us.....
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2010, 07:00 PM   #6
adrian k
adrian
adrian k's Avatar
It clicked over 80k on Friday (while Ford had it so a little ****ed i missed it clicking over :-)).
Interestingly today it felt much better, still flat, but no where near as bad as it has been. Ford said they cleaned the Maf element so whether that had anything to do with it i don't know.
I have another set of used sensors somewhere that i will stick in and see, reluctant to shell out for new ones unless i have to.
not sure if it makes any difference, but on the dyno it is super rich, but only richens up above 2k, the AFRs plumet to well below 10.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
Old 06-07-2010, 07:06 PM   #7
Windsor220
Now Fordless
Windsor220's Avatar
Thats normal for these things. Go ok until about 2500 and then the graph drops like a stone. If you get it tuned they will lean it out a bit.
Old 09-07-2010, 11:06 PM   #8
jaym
I Wish I Was A Post Whore
jaym's Avatar
Mines kindA similar just runs a bit rough till about 2000rpm :(
XR8 On 20s W00T W00T
www.aufalcon.com/jaysxr8
jaym is offline   Reply With Quote Multi-Quote with this Post
