This is a general question and may seem a bit silly but what role do the rear brakes actually play? When the brakes are applied, what percentage of work is done by the rears? Reason why I'm asking is because I've always wondered how you can do a standstill in an auto while applying brakes. Have they got anything to do with the handbrake?
Thanks guys |
Just another mock-up..
On the AU's the hand brake is seperate to the caliper..
The hand brake works similar to a drum brake setup on the inside of the brake disc near the hub, if that makes any sense.. also, i'm pretty sure that most cars braking is more biased to the front.. whether it be 60/40 or 70/30 or 80/20 etc.. i'm not to sure on exact...
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
yea that seems to clear up some questions for me. So naturally, if you were to do a burnout on the spot in an auto you would be doing no good for the car at all, what would most likely stuff up over time as the car isnt designed for that kinda stuff
Just slidin'
Ive done many, many, many burnouts in my au, with only a few breakages, all stemming from the one problem, which was an unbalanced tailshaft. Except for when I done the diff, that was just from pure abuse.
MD Mondeo - For the family
Walking with God
Don't know for sure, but I hear 80/20 Front/Rear thrown around in general conversation.
Someone here should know for sure though. GK
Flairs - Truckers Delight
Well i can only go off how long brake pads lasted in the cabs
in the AU1's we used to laugh at the fact that the front pads would last for 30k and the rears for 130k. In the AUII's it was something similar again, like 60k and 160k for front and back respectively. so around the 75/25 is about right, if wear = pressure
only done one standstill burnout, wasn't even that good, and it resulted in a dead diff (i think the original oil was still in it after 170k's). wife was not happy as she was 38 weeks pregnant and we needed the car to get to hospital.. one quick repair and i haven't been silly in the car since
You'll kill the transmission first an the diff next. Possibly warp your rear rotors but I'm not sure on that one
Current Blueprint 03 xr8 ![]() 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw ![]() ![]() BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
hmm, sound like burnouts in an auto is a no no...Yea i guess the system is similar to motorbikes where the front brakes play the primary role and are stronger than rears.
no, they're not a no-no
you just have to remember the 'you play, you pay' rule.
#11 | |||
True that
Au Falcon Ute S2 2001 Lowered on Kings with Bilistien Shocks all round 2.5inch cat back K&N Panel Filter FG XR6 17" Rims 245/45-17 tyres XR6T Snorkle BA front Caliper Conversion 300mm With Bendix Heavy Duty Pads Tow bar Transmission Cooler |
Just slidin'
When I went to Willo**** to do a world record attempt of most cars doing donuts at the same time, I broke many things, lol.
Tailshaft was out of balance so my extension housing broke, and the seal of course, and the bearing and bush. The output shaft was mangled, and I snapped the pulley on the power steering pump. This threw off the belt, and I overheated and cracked the radiator. Most expensive 30 seconds Ive ever had. Then the next time I went to Willowbank, I destroyed my LSD. Another $1000 in 10 seconds down the drain. Although, for the 5 years Ive been doing this stuff before hand, I hadnt had one problem.
#13 | |||
Former BTIKD
![]() Join Date: Mar 2005
VERY big discs too ![]()
#14 | ||
Fixing Ford's **** ups
70% front 30% rear.
#15 | |||
![]() Join Date: Jan 2005
#16 | ||
you can install a line locker where you have a on and off flow to the rear brakes so when you wanna burn out turn it off so no fluid goes to the back brakes and all at the front, did it to my old corolla
#17 | ||
How much does it cost and has anybody else done this before or recommend it?
#18 | ||
I heard that
#19 | |||
rexnet
#20 | ||
i can be done but wouldnt be drivin around with them all the time it'd be a bit dangerous, the tap works i was going to do it to mine soon ill put up a tutorial soon on aufalcon.com.au
