Old 03-08-2010, 07:28 PM   #1
XR6_4EVA
Hardcore I6 Enthusiast
XR6_4EVA's Avatar
Default Au rear irs strut tops
hey all, is someone able to show me a picture of what their rear suspension top mount looks like, i have a feeling the big washers and cap ontopt of the strut rubber were put on the wrong way round!
2002 AU XR6 VCT III 'ST'
Liquid Silver
Auto
Full Momo and Leather Trim.
Redback exhaust, high flow cat and Pacey Extractors.
SELLING MY GENUINE 18" AZZUROS WITH TYRES.
FRONT TYRES 95%
REAR TYRES 50%
XR6_4EVA is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 08:08 PM   #2
Papa Smurf
Papa Smurf's Avatar
Hope this helps
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 08:18 PM   #3
XR6_4EVA
XR6_4EVA's Avatar
thanks heaps man but i cant really tell in the picture whic way around part number 9 is meant to sit, if i bolt it down with part 9 cupping towards the strut so it squashes the rubber, the noise is fixed, if i have it cupping towards the roof of the car theres play in the strut and it knocks
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 03-08-2010, 08:31 PM   #4
mik
mik's Avatar
i just had a look at mine, they face upwards (bowl to the top).
Old 03-08-2010, 08:47 PM   #5
XR6_4EVA
XR6_4EVA's Avatar
by bowl to the top you mean it could be filled with water or the water will just run off it
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 03-08-2010, 11:16 PM   #6
EV1LXR8
EV1LXR8's Avatar
yes filled with water like a dish
EV1LXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 11:23 PM   #7
stoodoo
Falcon R.I.P. 1960 - 2016
stoodoo's Avatar
it should be oriented so that it would "fill with water" so to speak.
stoodoo is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 01:10 AM   #8
mik
mik's Avatar
exactly........
Old 04-08-2010, 06:33 AM   #9
XR6_4EVA
XR6_4EVA's Avatar
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 04-08-2010, 06:52 AM   #10
XR6_4EVA
XR6_4EVA's Avatar
ignore that last post, compputers fault, damnit, iif i place it so it fills like a dish, the struts knock alot, i had the rubbers replaced a year ago....
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 04-08-2010, 09:08 AM   #11
Jimmyd
You will need to fit a spacer washer between the mount (#10/11 above) and the "dish" washer (#9) - the stepped section of the strut is too long (or conversely, the mount inner sleeve is too short) so "dish" (#9) bottoms out on the shoulder before it clamps down on the sold centre sleeve of the mount (#10/11). Make sure the spacer washer will fit over the shoulder section but does not overhang the solid centre of the mount. If you turn the "dish" (#9)over all you are doing is locking up the upper mount.
Quick sketch to explain the above;
Drawn from memory so may not be 100% correct in all detail, but near enough for you to get the idea.
This was an issue from day one and is the most common reason the rear mounts fail - you would have most likely seen your old mounts had a oval centre hole rather than round when you replaced them....
When we had failures during warranty periods we did this as an 'in field' service modification when fitting the replacement mounts.
James
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 10:21 AM   #12
ronwest
All Bran = Regular Member
Nice work.
Be right at home in the "Useful AU threads" sticky...
Old 04-08-2010, 10:22 AM   #13
mik
mik's Avatar
XR6 4EVA i stumbled across this gem of a thread, i don`t know if you are having the same problem as in this thread ..... i know it has Koni`s but see what you think.
http://www.fordforums.com.au/showthread.php?t=11244643
Old 04-08-2010, 12:22 PM   #14
XR6_4EVA
XR6_4EVA's Avatar
perfect !! Thanks so much lads especially jimmy! Cheers for your quick responses!
Liquid Silver
Auto
FRONT TYRES 95%
REAR TYRES 50%
Old 04-08-2010, 06:40 PM   #15
adrian k
adrian
adrian k's Avatar
Spacer is supposed to go under the top nut, ie ontop of the dished plate. Prob wont make too much difference though.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 07:13 PM   #16
cedric
have a good look at the picture. on top of the washer won't do anything.it has run out of thread,so to speak. i drilled out my 'curved' washer so when more washers,also larger than shaft, were used they did not hit the step in the shaft
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 08:36 PM   #17
adrian k
adrian
adrian k's Avatar
It may be different on the Konis, but this is exactly how my TS was.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
