Old 02-08-2010, 09:18 PM   #1
macman
macman's Avatar
Default AU Horn
So the horn on my AU TS50 doesn't work... Press either horn button - nothing happens...
So I removed the horn/air bag to test it in my other AU (TE50) and the moment I plugged it in, the horn blares without even pressing the button!?!
Any ideas what might be going on?
macman is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 12:06 AM   #2
sleeper393
sleeper393's Avatar
me thinks your horn is haunted , lol, electrical fault, short
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak!
AU SERIES 3 LIQUID SILVER
BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS
123.4 GROUND TEARING RWKW'S , LOL
sleeper393 is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 08:06 AM   #3
JK EX CHASER
Formally kotevski22
JK EX CHASER's Avatar
Check the horn switch with a ohms meter to see if the switch is stuck on.
JK EX CHASER is offline   Reply With Quote Multi-Quote with this Post
Old 03-08-2010, 11:14 AM   #4
whiskers
gone fishing
whiskers's Avatar
also could very well be the air bag is no longer working or even the clock spring. same sort of thing was wrong with mine the horn kept on going off ie it was blaring all the time had to pull the fuse in the end.
It turned out to be the air bag was stuffed, got another of ebay and all good now for 5 years
Whiskers
Old 05-08-2010, 07:08 PM   #5
macman
macman's Avatar
Thanks guys. I'm sorry for the simple question, sometimes it just really helps to think out aloud and get fresh responses.
Turns out it was a combination of things (which always makes diagnosis more difficult).
Faulty airbag/horn assembly (stuck ON) and missing fuse (obviously taken out as a quick-fix).
Thanks guys, should have a fuse and new airbag on it's way soon.
