Old 30-10-2010, 01:42 PM   #1
Swedishmoose
Default Hard to start
Hi ...
2000 AU Falcon Futura 4 litre 4 speed auto...
Can anybody tell me why our Falcon is hard to start when it is parked on a slope?
When the nose sits lower than the rear end it is hard to start and it sometimes takes two or three attempts.
When the rear sits lower than the nose it is not as bad but the car starts best when it parks on a levelled ground.
It has never done it before and it usually never caused any problems.
It has got new spark plugs and news leads becaus ethey were bad.
Could it be a weak fuel pump or a clogged fuel filter ? That was my first guess.
Anyone got any other ideas ?
Would be happy to get some feedback
The Moose
Swedishmoose is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2010, 02:31 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
I would go with the pump and filter option.. both are a relatively easy and cheap fix
Originally Posted by Riksta
Old 30-10-2010, 02:49 PM   #3
vibe_xr6
vibe_xr6's Avatar
my au used to be a ***** to start if ii rushed it, i used to have to turn the key on and wait for the lights to go off on the dash (fuel pump prime) then start it
Completely Stock
vibe_xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2010, 03:27 PM   #4
Swedishmoose
Hi there...
well...I am not rushing it at all...
I turn ignition on wait for the fuel pump to stop pumping and then turn the key...
it cranks as usual and then the engine doesn't know what it wants to do....it fires a couple times and runs all shaky and stops again...second attempt...
turn ignition on...fuel pump goes ...weeeeeeee.....fuel pump stops pumping fuel to the fuel ignition rail...
I start and then it starts..
its weird...it only does it when parked on a slope and the nose sits lower than the rear end ( not even very steep).
It runs absolutely smooth and no problems at all.
The Moose
Old 30-10-2010, 04:09 PM   #5
frd906
i have the same thing happen to me a couple of times, turned out to be my spark plugs
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2010, 04:20 PM   #6
Swedishmoose
Hey...
but I just changed them....and the leads too and it has done it before I changed them..
I was thinking a fuel related issue because when the car parks levelled its all ok...only on a slope it plays up ...
weird...
Old 30-10-2010, 04:30 PM   #7
frd906
did u change the coil pack?
Old 30-10-2010, 06:16 PM   #8
Swedishmoose
Hey...
no I didn't because after I changed the plugs and the leads the main issues (misfiring , stalling ) were gone...
The coil pack is still the same....but why do you think its the coil pack ?
why does the Falcon starts perfectly well on a levelled ground and only plays up when I wanna start it when its parked on a slope ?
If it is the coil pack it should also play up on a levelled ground or am i wrong ?
The Moose
Old 30-10-2010, 06:20 PM   #9
TheInterceptor
Cruising...
TheInterceptor's Avatar
If it runs shakey...id put my money on the fuel pump. Had the same type of thing happen apart from it refused to start, turn the key, just shakes about violently...
Had to whack the fuel tank while dad was cranking it for it to start working properly haha.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
